Next revision | Previous revision Next revision Both sides next revision | ||
default_encoder_assignments [2010/09/19 14:32] jrock created 9/19/2010 |
default_encoder_assignments [2011/07/12 13:03] rahulmitchell |
Line 1: | Line 1: | ||
======Default Encoder Assignments====== | ======Default Encoder Assignments====== | ||
- | I've been working on my own CS for MB6582. It's totally based on Wilba and TK's CS but since I traced all the encoders back to the PCB and marked their functions down it's easy enough for me to enter it in here for future users. They are in no particular order so feel free to fiddle around with this. | ||
Each of the different engines have slightly different functions for the encoders but this should give you a list of the most common ones. | Each of the different engines have slightly different functions for the encoders but this should give you a list of the most common ones. | ||
- | You can change them too But this should give you a running start | + | You can change them but this will give you a point of reference. |
==JD1== | ==JD1== | ||
Line 31: | Line 30: | ||
D6/D7 = Filter Resonance | D6/D7 = Filter Resonance | ||
+ | [[http://cvresumewritingservices.org/|resume writing services]] | ||
