default_encoder_assignments
Differences
Next revision | Previous revisionLast revisionBoth sides next revision | ||
default_encoder_assignments [2010/09/19 14:32] – created 9/19/2010 jrock | default_encoder_assignments [2011/07/14 07:51] – rahulmitchell1 | ||
Line 1: | Line 1: | ||
======Default Encoder Assignments====== | ======Default Encoder Assignments====== | ||
- | I've been working on my own CS for MB6582. It's totally based on Wilba and TK's CS but since I traced all the encoders back to the PCB and marked their functions down it's easy enough for me to enter it in here for future users. They are in no particular order so feel free to fiddle around with this. | ||
Each of the different engines have slightly different functions for the encoders but this should give you a list of the most common ones. | Each of the different engines have slightly different functions for the encoders but this should give you a list of the most common ones. | ||
- | You can change them too But this should | + | You can change them but this will give you a point of reference. |
==JD1== | ==JD1== | ||
Line 30: | Line 29: | ||
D4/D5 = Oscillator Delay | D4/D5 = Oscillator Delay | ||
D6/D7 = Filter Resonance | D6/D7 = Filter Resonance | ||
+ | [[http:// | ||
default_encoder_assignments.txt · Last modified: 2011/09/17 17:27 by dougster
