Next revision Both sides next revision | |||
dictionary:assembly [2007/11/17 18:01] 127.0.0.1 external edit |
dictionary:assembly [2011/07/12 13:03] rahulmitchell |
Line 1: | Line 1: | ||
A programming language that is once removed from machine language. Machine languages consist entirely of numbers and are almost impossible for humans to read and write. Assembly languages have the same structure and set of commands as machine languages, but they enable a programmer to use names (mnemonics) instead of numbers. | A programming language that is once removed from machine language. Machine languages consist entirely of numbers and are almost impossible for humans to read and write. Assembly languages have the same structure and set of commands as machine languages, but they enable a programmer to use names (mnemonics) instead of numbers. | ||
+ | [[http://essaywritingservices.org/prices.php|write my essay]] | ||
