dipboardf4 [2018/11/03 01:06] phatline [BOM] |
dipboardf4 [2018/11/03 02:36] phatline [BOM] |
Line 43: | Line 43: | ||
version 1. | version 1. | ||
Mouser BOM:<wrap round todo 7%>toDo</wrap> | Mouser BOM:<wrap round todo 7%>toDo</wrap> | ||
- | ^Qty ^Value ^Package ^Parts ^Mouser^Reichelt^Conrad^Other^Notes^ | + | ^Qty ^Value ^Package ^Parts ^Mouser^Reichelt^Conrad^LCSC^Notes^ |
^Resistors^^^^^^^^^ | ^Resistors^^^^^^^^^ | ||
|2 |680R 5% |0603 |R1, R2 |[[https://www.mouser.fr/ProductDetail/Panasonic/ERJ-PA3J681V?qs=sGAEpiMZZMvdGkrng054t6%2fAfIpq60YDGGtXI%252bjCSgEeBlnz3sOAbg%3d%3d| 667-ERJ-PA3J681V | |2 |680R 5% |0603 |R1, R2 |[[https://www.mouser.fr/ProductDetail/Panasonic/ERJ-PA3J681V?qs=sGAEpiMZZMvdGkrng054t6%2fAfIpq60YDGGtXI%252bjCSgEeBlnz3sOAbg%3d%3d| 667-ERJ-PA3J681V | ||
]] | | |[[https://lcsc.com/product-detail/Chip-Resistor-Surface-Mount_680R-681-5_C103784.html|C103784]] |Depends on Leds | | ]] | | |[[https://lcsc.com/product-detail/Chip-Resistor-Surface-Mount_680R-681-5_C103784.html|C103784]] |Depends on Leds | | ||
- | |4 |1K 5% |0603 |R3, R4, R5, R6 |[[https://www.mouser.fr/ProductDetail/ROHM-Semiconductor/ESR03EZPJ102?qs=%2fha2pyFadujPfy170iHVGEtMFtzogPGwOHcYAAOLl%2f9T6PIvTHXpgQ%3d%3d|755-ESR03EZPJ102 ]] | | | |R3 if you use CAN without transceiver| | + | |4 |1K 5% |0603 |R3, R4, R5, R6 |[[https://www.mouser.fr/ProductDetail/ROHM-Semiconductor/ESR03EZPJ102?qs=%2fha2pyFadujPfy170iHVGEtMFtzogPGwOHcYAAOLl%2f9T6PIvTHXpgQ%3d%3d|755-ESR03EZPJ102 ]] | | |[[https://lcsc.com/product-detail/Others_ROHM-Semicon_ESR03EZPJ102_ROHM-Semicon-ESR03EZPJ102_C253329.html|C253329 ]] |R3 if you use CAN without transceiver| |
^PTC fuses, resettable thermistors^^^^^^^^^ | ^PTC fuses, resettable thermistors^^^^^^^^^ | ||
- | |1 |1206L150THWR|1206|F1|[[https://www.mouser.fr/ProductDetail/Littelfuse/1206L150THWR?qs=%2fha2pyFaduhlexFGoLte04X2tL%252bbW3Ma%252b9epP3LU68QBDZh6rRT18Q%3d%3d|576-1206L150THWR]] | | | | | | + | |1 |1206L150THWR|1206|F1|[[https://www.mouser.fr/ProductDetail/Littelfuse/1206L150THWR?qs=%2fha2pyFaduhlexFGoLte04X2tL%252bbW3Ma%252b9epP3LU68QBDZh6rRT18Q%3d%3d|576-1206L150THWR]] | | |[[https://lcsc.com/product-detail/PTC-Resettable-Fuses_TLC-Electronic-TLC-NSMD150_C261956.html| |
+ | C261956]] | | | ||
^Capacitors^^^^^^^^^ | ^Capacitors^^^^^^^^^ | ||
|1 |100n |0603|C2 |[[https://www.mouser.fr/ProductDetail/KEMET/C0603C104Z3VACTU?qs=sGAEpiMZZMs0AnBnWHyRQFqPnX0Olvco%252bYoiWDWTaEY%3d| 80-C0603C104Z3V | |1 |100n |0603|C2 |[[https://www.mouser.fr/ProductDetail/KEMET/C0603C104Z3VACTU?qs=sGAEpiMZZMs0AnBnWHyRQFqPnX0Olvco%252bYoiWDWTaEY%3d| 80-C0603C104Z3V | ||
- | ]] | | | | | | + | ]] | | | [[https://lcsc.com/product-detail/Multilayer-Ceramic-Capacitors-MLCC-SMD-SMT_SAMSUNG_CL10F104ZB8NNNC_100nF-104-80-20-50V_C1688.html| |
+ | C1688]] | | | ||
|1 |47u Tantalum |SMC_B(1210)|C1 |[[https://www.mouser.fr/ProductDetail/Vishay-Sprague/TMCMB1C476MTRF?qs=sGAEpiMZZMuEN2agSAc2pqyLMxN%252bdaSr1ZUobrj8juKxspNLmKYGKA%3d%3d| | |1 |47u Tantalum |SMC_B(1210)|C1 |[[https://www.mouser.fr/ProductDetail/Vishay-Sprague/TMCMB1C476MTRF?qs=sGAEpiMZZMuEN2agSAc2pqyLMxN%252bdaSr1ZUobrj8juKxspNLmKYGKA%3d%3d| | ||
- | 74-TMCMB1C476MTRF ]] | | | | | | + | 74-TMCMB1C476MTRF ]] | | | [[https://lcsc.com/product-detail/Tantalum-Capacitors_47uF-476-10-16V_C112105.html|C112105]] | | |
^Diode^^^^^^^^^ | ^Diode^^^^^^^^^ | ||
- | |1 |1N4148WS|SOD323-W|D1 |[[https://www.mouser.fr/ProductDetail/ON-Semiconductor-Fairchild/1N4148WS?qs=sGAEpiMZZMtoHjESLttvkr4bXZrJfFziTdC5C0Y1oek%3d|512-1N4148WS ]] | | | |Only if you use CAN without transceiver | | + | |1 |1N4148WS|SOD323-W|D1 |[[https://www.mouser.fr/ProductDetail/ON-Semiconductor-Fairchild/1N4148WS?qs=sGAEpiMZZMtoHjESLttvkr4bXZrJfFziTdC5C0Y1oek%3d|512-1N4148WS ]] | | |[[https://lcsc.com/product-detail/Switching-Diode_1N4148WS_C108805.html| |
+ | C108805]] |Only if you use CAN without transceiver | | ||
^LEDs^^^^^^^^^ | ^LEDs^^^^^^^^^ | ||
- | |2 |--|0805 |5V, 3V3 |[[https://www.mouser.fr/ProductDetail/755-SML-H12U8TT86C|755-SML-H12U8TT86C]] | | | | | | + | |2 |--|0805 |5V, 3V3 |[[https://www.mouser.fr/ProductDetail/755-SML-H12U8TT86C|755-SML-H12U8TT86C]] | | |[[https://lcsc.com/product-detail/Light-Emitting-Diodes-LED_0805-Red-LED-Iv-61mcd-Typ-atIF-20mA_C72037.html|C72037]] | | |
^dipCoreF4 socket^^^^^^^^^ | ^dipCoreF4 socket^^^^^^^^^ | ||
- | |2 |1x20 |low profile female| |[[https://www.mouser.fr/ProductDetail/517-929870-01-20-RA| 517-929870-01-20-RA]] | | | |for pads 1 to 40| | + | |2 |1x20 |low profile female| |[[https://www.mouser.fr/ProductDetail/517-929870-01-20-RA| 517-929870-01-20-RA]] | | |[[https://lcsc.com/product-detail/Female-Header_2-54mm-1-40P-round-Female-header_C9811.html|C9811]] |for pads 1 to 40| |
- | |2 |1x5 |low profile female| |[[https://www.mouser.fr/ProductDetail/3M-Electronic-Solutions-Division/929870-01-05-RA?qs=sGAEpiMZZMs%252bGHln7q6pm%252bCiuHjnbsudfRsikv%252bK%252bu4%3d|517-929870-01-05-RA ]] | | | |for pads 41 to 50| | + | |2 |1x5 |low profile female| |[[https://www.mouser.fr/ProductDetail/3M-Electronic-Solutions-Division/929870-01-05-RA?qs=sGAEpiMZZMs%252bGHln7q6pm%252bCiuHjnbsudfRsikv%252bK%252bu4%3d|517-929870-01-05-RA ]] | | |no need break it down from below|for pads 41 to 50| |
- | |1 |1x2 |low profile female| |[[https://www.mouser.fr/ProductDetail/3M-Electronic-Solutions-Division/929870-01-02-RA?qs=sGAEpiMZZMs%252bGHln7q6pm%252bCiuHjnbsudnrpQb%2fhOxhg%3d|517-929870-01-02-RA ]] | | | |for pads 51 to 52| | + | |1 |1x2 |low profile female| |[[https://www.mouser.fr/ProductDetail/3M-Electronic-Solutions-Division/929870-01-02-RA?qs=sGAEpiMZZMs%252bGHln7q6pm%252bCiuHjnbsudnrpQb%2fhOxhg%3d|517-929870-01-02-RA ]] | | |[[https://lcsc.com/product-detail/Female-Header_2-54mm-1-40P-round-Female-header_C9811.html|C9811]] |for pads 51 to 52| |
^Connector^^^^^^^^^ | ^Connector^^^^^^^^^ | ||
- | |1 |micro-match 2x6 |Female|J1A |[[https://www.mouser.fr/ProductDetail/TE-Connectivity-AMP/8-215079-2?qs=sGAEpiMZZMs%252bGHln7q6pm8SOCK6aAoLg1R8%252bHzdf0ck%3d|571-8-215079-2]] or [[https://www.mouser.fr/ProductDetail/TE-Connectivity/1-2178710-2?qs=sGAEpiMZZMs%252bGHln7q6pmzszEaJ39Bz8Bh9SlB9BUSeJ3BKKERN%252bmg%3d%3d|571-1-2178710-2 (value line)]] | | | |Place on top | | + | |1 |micro-match 2x6 |Female|J1A |[[https://www.mouser.fr/ProductDetail/TE-Connectivity-AMP/8-215079-2?qs=sGAEpiMZZMs%252bGHln7q6pm8SOCK6aAoLg1R8%252bHzdf0ck%3d|571-8-215079-2]] or [[https://www.mouser.fr/ProductDetail/TE-Connectivity/1-2178710-2?qs=sGAEpiMZZMs%252bGHln7q6pmzszEaJ39Bz8Bh9SlB9BUSeJ3BKKERN%252bmg%3d%3d|571-1-2178710-2 (value line)]] | | |no!|Place on top | |
^3 options available for PORTs connectors(depends on you app.) ^^^^^^^^^ | ^3 options available for PORTs connectors(depends on you app.) ^^^^^^^^^ | ||
^Option 1 - Regular Shrouded Headers^^^^^^^^^ | ^Option 1 - Regular Shrouded Headers^^^^^^^^^ | ||
- | |3 |2x3 |Male |J5, J11, J18 |[[https://www.mouser.fr/ProductDetail/Wurth-Electronics/61200621621?qs=sGAEpiMZZMs%252bGHln7q6pm%2fFhW%252btWvhAgbNxkR%252blwXp8Ip%2fAN9J9VOg%3d%3d|710-61200621621 ]] | | | |Place on top | | + | |3 |2x3 |Male |J5, J11, J18 |[[https://www.mouser.fr/ProductDetail/Wurth-Electronics/61200621621?qs=sGAEpiMZZMs%252bGHln7q6pm%2fFhW%252btWvhAgbNxkR%252blwXp8Ip%2fAN9J9VOg%3d%3d|710-61200621621 ]] | | |[[https://lcsc.com/product-detail/Header-Connectors_Shenzhen-Cancome-2-54mm-2-3P-Straight-IDC-Box_C132438.html|C132438]] |Place on top | |
- | |4 |2x5 |Male |J4, J8/9, J15, J19 |[[https://www.mouser.fr/ProductDetail/Wurth-Electronics/61201021621?qs=sGAEpiMZZMs%252bGHln7q6pm%252bxnWLfLL2%2f93mYWvuMVZAY%3d|710-61201021621 ]] | | | |Place on top | | + | |4 |2x5 |Male |J4, J8/9, J15, J19 |[[https://www.mouser.fr/ProductDetail/Wurth-Electronics/61201021621?qs=sGAEpiMZZMs%252bGHln7q6pm%252bxnWLfLL2%2f93mYWvuMVZAY%3d|710-61201021621 ]] | | |[[https://lcsc.com/product-detail/PCB-Connectors-Headers-Male-Pins_Shenzhen-Cankemeng-2-54mm-2-5P-Straight-IDC-Box_C132435.html|C132435]] |Place on top | |
- | |1 |2x7 |Male |J16E |[[https://www.mouser.fr/ProductDetail/Wurth-Electronics/61201421621?qs=sGAEpiMZZMs%252bGHln7q6pm%2fFhW%252btWvhAggwcPHCC2CMNxOm0Mua7X2Q%3d%3d|710-61201421621 ]] | | | |Place on top | | + | |1 |2x7 |Male |J16E |[[https://www.mouser.fr/ProductDetail/Wurth-Electronics/61201421621?qs=sGAEpiMZZMs%252bGHln7q6pm%2fFhW%252btWvhAggwcPHCC2CMNxOm0Mua7X2Q%3d%3d|710-61201421621 ]] | | |[[https://lcsc.com/product-detail/Header-Connectors_Shenzhen-Cancome-2-54mm-2-7P-Straight-IDC-Box_C132432.html|C132432]] |Place on top | |
^Option 2 - Stacking Micro-Match Connector^^^^^^^^^ | ^Option 2 - Stacking Micro-Match Connector^^^^^^^^^ | ||
|1 |2x2 |Female |J1B |[[https://www.mouser.fr/ProductDetail/TE-Connectivity-AMP/7-215079-4?qs=sGAEpiMZZMs%252bGHln7q6pm8SOCK6aAoLgAB%252bkBgSN8jE%3d|571-7-215079-4]] or [[https://www.mouser.fr/ProductDetail/TE-Connectivity/2178710-4?qs=sGAEpiMZZMs%252bGHln7q6pmzszEaJ39Bz8xlKrGrnZbKU8jgpyiX7BKg%3d%3d|571-2178710-4 (value line)]] | | | |Place on bottom | | |1 |2x2 |Female |J1B |[[https://www.mouser.fr/ProductDetail/TE-Connectivity-AMP/7-215079-4?qs=sGAEpiMZZMs%252bGHln7q6pm8SOCK6aAoLgAB%252bkBgSN8jE%3d|571-7-215079-4]] or [[https://www.mouser.fr/ProductDetail/TE-Connectivity/2178710-4?qs=sGAEpiMZZMs%252bGHln7q6pmzszEaJ39Bz8xlKrGrnZbKU8jgpyiX7BKg%3d%3d|571-2178710-4 (value line)]] | | | |Place on bottom | |
