dipCoreF4
A reduced Core for your MIDIbox App, an STM32F405RG in a DIP40 format.
Features
MIOS32 uses same processor family and drivers(no deep change).
Same internal hardware as Disco or wCore (speed, memory, peripherals, etc…) .
Board pinout and package compatible with a MIOS8 PIC
USB connector onboard.
5V power input and led.
3.3V regulator and led on board.
74HCT541 on board for the 5V output ports.
User and Reset buttons.
2 user leds.
8 extra pins for USB, buttons and leds.
Your favorite Core is now a current component easy to integrate.
All commons MIOS32 ports are available except:
General purpose J10x ports were removed.
LCD port was reduced to a serial one, no more pins J15.D0-D7
2 UART only(2 MIDI In/2Out).
2 AIN channels only(e.g. pedal inputs)
Check the dipBoardF4 for more details
Download
PCB
4 layers PCB design.
Fits 4 layer mostly common design rules.
min. drill 10mil
min. width 5mil
Pinout
First, was a chart.
This chart gives you the equivalence between the different pinout and functions.
The dipCoreF4 and the legacy MIOS32 ports.
Check dipBoardF4 for more details about the connectors.
407VG vs 405RG
Legacy STM32F407 and 405 share the same characteristics.
The 405RG is a TQFP64, a 10x10mm package and only 64 pins.
No Ethernet MAC and camera interface.
ST STM32F4xx series
In MIOS32
We use the same peripheral drivers same family, some compilation defined conditions were added for the specific pinout and type, number of ports.
toDo
