easy_cv
Differences
Link to this comparison view
Both sides previous revision Previous revision
Next revision
Previous revision
Last revision Both sides next revision
easy_cv [2016/08/10 02:34]
phatline [VCA-VCF]
easy_cv [2016/08/14 23:24]
phatline [Example for a Filterbank]
Line 6: Line 6:
 ===== Introduction ===== ===== Introduction =====
-Digital created LFO+ENV with CV-Output. +All Parameters are saved as a preset as a song (programchange...)\\
-No Displays, No Menues, Minimal buttons, much Scopes, much Led-Ring-Rotarys (Planed for LRE-8x2CS)one big UI with complete functions for one LFO+ENV Voice... ​switching between the UI-Voices is done from the BREAKOUTMODULES...to this later+Digital created LFO+ENV with CV-Output.\\
 +No Displays, No Menues, Minimal buttons, much Scopes, much Led-Ring-Rotarys (LRE-8x2CS)\\
 +one big UI with complete functions for one LFO+ENV Voice + 4xChannelstrip Controlls... \\
 LFO+ENV are mixed together softwareside,​ to use only one CV-Output\\ LFO+ENV are mixed together softwareside,​ to use only one CV-Output\\
-8xCV-Outputs ​(VOICES) are supported > if u are on a VCF+VCA-Setup = 4 Voices on the Analog-Side (4xFilterbank)\\+Each Channel = Filter need 8xCV-Outputs\\
 Copy Paste for LFOs and ENVelopes between the Voices\\ Copy Paste for LFOs and ENVelopes between the Voices\\
-Copy Paste for a Songa aka Preset aka Bank aka Program(change)\\+Copy Paste for a Song aka Preset aka Bank aka Program(change)\\
 Jam Style Pattern load (next Preset Display) + Preset Morph between Current-Preset and Next-Preset\\ Jam Style Pattern load (next Preset Display) + Preset Morph between Current-Preset and Next-Preset\\
 +The Early Design was a EuroRack-Module:​
 A Breakoutmodule for each CV-Output, with Depth-rotary,​ Focusswitch (Pushrotary),​ 2x Scopes (LFO+ENV) and LFO/​ENV-Switch to show on one Display the Mixed Waveform & to switch the Rotary to "​ENV"​ or "​LFO"​ Mode (there is only space for one Encoder - maybe just make PAN Style, instead of 2 individual level -maybe more live feel?, how ever when using an 3Stage switch, i could disable MIX-View, or display it on ENV or LFO...maybe a good choise ;) ) A Breakoutmodule for each CV-Output, with Depth-rotary,​ Focusswitch (Pushrotary),​ 2x Scopes (LFO+ENV) and LFO/​ENV-Switch to show on one Display the Mixed Waveform & to switch the Rotary to "​ENV"​ or "​LFO"​ Mode (there is only space for one Encoder - maybe just make PAN Style, instead of 2 individual level -maybe more live feel?, how ever when using an 3Stage switch, i could disable MIX-View, or display it on ENV or LFO...maybe a good choise ;) )
 The Depth-rotary has no Ledring, want to display it as a bar or as Value in the scope... The Depth-rotary has no Ledring, want to display it as a bar or as Value in the scope...
-Whole thing will not be compatible on MB-CV concepts... i will copy code snippets and so on, but i have to understand it from scratch... anyhow this is not generic
 ===== FrontPanel ===== ===== FrontPanel =====
 ==== Brain ==== ==== Brain ====
Line 51: Line 53:
 ==== BreakOut ==== ==== BreakOut ====
 +**this will not be supportet > since i dont want a Euro-Module Setup > i want one big filterbox.**\\
 1. Discharged UserInterface for the Brain in "​Island mode" (Scopes + Digital-CV-Amount)\\ 1. Discharged UserInterface for the Brain in "​Island mode" (Scopes + Digital-CV-Amount)\\
 2. CV-Breakout EuroModule to be located near the CV-Destination (example: a Filter).\\ 2. CV-Breakout EuroModule to be located near the CV-Destination (example: a Filter).\\
Line 100: Line 103:
 ==== Example for a Filterbank ==== ==== Example for a Filterbank ====
-Here are 8Envelopeś 4xfor VCF 4xfor VCA... in fact there could be used more then this for example 8xVCF and 8xVCA...since the BREAK-OUT-Modules are Modular, and they share the same "​Main-UI"​...the only limiting factor ​is the CODE...i am not a C-Guru, and maybe i will still have timing problems with 8x CV-Outs...we will see.+EUROMODULE-BASED >>>​ It is not planed to do it that way (just for you to get some input)
 {{ :​phatline:​Easy-CV-Example.jpg?​direct&​900 |}}  {{ :​phatline:​Easy-CV-Example.jpg?​direct&​900 |}}
-**I will use it to filter:**\\
-2xGuitar-Loopstations\\
-1xGuitar\\
-1xPercussion-Master\\
-A not EUROMODULE-BASED Version of something like this is the FILTERBOX:+A not EUROMODULE-BASED Version of something like this is the FILTERBOX: ​\\
 +(this is the Design I prefer @ the moment)
 {{:​phatline:​easy-cv-filterbox.png|}} {{:​phatline:​easy-cv-filterbox.png|}}
 +Filterbox OneChannel > first idea of Block-shematic:​
 +{{:​phatline:​filterbank-channelstrip.jpg|}}
 ===== General Design ===== ===== General Design =====
-The panel size is 3UEurorack compliant ​+The Panel is made of transparent but shadet (black transparent) Plexiglass.\\
 +The Panel is directly mounted into a Flightcase.\\
 +The 3x LRE8x2 (LEDRING) are mounted with the Encoder Nutsthe rest of the PCBs are mounted with normal thruhole screws.\\
 ==== FrontPanel ==== ==== FrontPanel ====
 ==== PCBs ==== ==== PCBs ====
- +**The Analog-IO Board on the Backpanel, holds:​**\\
-The Analog ​Circuits (VCF+VCA) get sandwitch as normal (not90° angeled) ​\\+-the ENV-VCAs\\
 +-the DryWet-VCAs,​ Filter-Releay-Switch\\
 +-SEND-EFX-VCAs\\
 +-the Summing Mixer\\
 +-the Ducking-Cross-AMP-Follower+Ducking-VCAs\\
 +-VCF+ENV-VCA-Distortion-Driver-VCAs\\
 +-the Connectors to connect the Filter, AOUT, Poti-Boards\\
 Left-Part of the Brain on Breathboard:​ \\ Left-Part of the Brain on Breathboard:​ \\
-7Segment: LTS547AP ​\\ +OLED-Display ​\\
-Button: ShadowSE/​ITT \\+Button: ShadowSE/​ITT\\
 +ENCODER: with built in Pushswitch\\
 +a early state with 7Segment Displays to indicate the Patches\\
 {{:​phatline:​proto-preset.jpg?​400|}} {{:​phatline:​proto-preset.jpg?​400|}}
-==== 3D View of Sandwitches ====
-FIXME make concept
 ==== 1. UI Parts Listing ​ ==== ==== 1. UI Parts Listing ​ ====
 === BRAIN + BREAKOUT === === BRAIN + BREAKOUT ===
-  * [[https://​www.thonk.co.uk/​shop/​3-5mm-jacks/​| Jacks 3.5mm @ Thonk]] +  * 6,Neutrik Connector\\
-  * [[http://​at.rs-online.com/​web/​p/​kippschalter/​7347145|SPDT Switch ​ON-OFF-ON ​@ Rs-components]]+  * [[http://​at.rs-online.com/​web/​p/​kippschalter/​7347145|FLASH-Switch @ Rs-components]]
 ^ Value     ​^ ​ Type                    ^ Qty  ^ ^ Value     ​^ ​ Type                    ^ Qty  ^
-|3.5mm Jack |Vertical PCB-Mount ​       |13    |
 |Switch ​    |SPDT Vertical PCB-Mount ON-OFF-ON ​  ​|1 ​    | |Switch ​    |SPDT Vertical PCB-Mount ON-OFF-ON ​  ​|1 ​    |
 FIXME Fill Table FIXME Fill Table
Line 145: Line 153:
   * [[https://​www.thonk.co.uk/​shop/​alpha-9mm-pots/​|Alpha Pots @ Thonk]]   * [[https://​www.thonk.co.uk/​shop/​alpha-9mm-pots/​|Alpha Pots @ Thonk]]
   * [[where_to_order_components#​knobs|Knobs Suppliers]]   * [[where_to_order_components#​knobs|Knobs Suppliers]]
-  * FIXME need special 4gang 50KB potentiometers ​for a STEREO Resonance (stereo filter, one UI) +  * FIXME which Values ​for the Audio-Mixer?
-  * FIXME need special 4gang xxKB (50?) potis for a Stereo DRY/WET Mix +
-  * FIXME need special 2gang xxKB (50?) potis for EFX Send Mix Stereo +
-  * FIXME need special 2gang 50KA       potis for CUT-OFF Stereo +
-  * FIXME need special 2gang Post Transformator Potentiometer (Value have to look in my prototype which is used)+
-^ Value   ​^ ​ Type          ^ Qty  ^
-|5K       ​|Linear ​         |x     |
-|10K      |Linear ​         |x     |
-|50K      |Linear ​         |x     |
-|50K      |Logarithmic ​    ​|x ​    |
-|100K     ​|Linear ​         |x     |
-|1M       ​|Linear ​         |x     |
-|2M?      |Linear ​         |x     |
-|Knobs ​   |Soft/​Plastic/​Alu|x ​    |
-==== 2. Analog Parts Listing ====
-=== VCA-VCF-Board ===
-FIXME Fill Table
 ==== 3.Footprint Making in KiCAD ==== ==== 3.Footprint Making in KiCAD ====
Line 172: Line 160:
   * ALPS Pots   * ALPS Pots
   * Alpha Pots   * Alpha Pots
-  * 3,5mm Jack+  * 6,3mm Jack
   * Switch   * Switch
   * Momentary Switch   * Momentary Switch
-  * 7 Segment LED Display+  * SSD-Displays
   * OLED DIsplay   * OLED DIsplay
   * Rotary Encoder   * Rotary Encoder
Line 190: Line 178:
  ​a.Left-Brain\\  ​a.Left-Brain\\
  ​b.Right-Brain\\  ​b.Right-Brain\\
-- LRE8x2CS - is a generic PCB which i already have (fairlightiiś)\\ +3x LRE8x2CS - is a generic PCB which i already have (fairlightiiś)\\
-BREAKOUT PCBs (maybe have to sandwitch because of shiftregisters and less space)\\ +Backpanel PCB\\
-- FILTER PCBs (have to sandwitch)\\+- FILTER PCBs\\
easy_cv.txt · Last modified: 2016/08/22 02:03 by phatline
