electronics_basics [2016/06/10 12:06] psykhaze [6 - Analog / Digital, what's the difference?] |
electronics_basics [2016/06/15 10:51] psykhaze [11 - Going Further] |
Line 227: | Line 227: | ||
**BJT**s and **FET**s perform **similar** functions, but with a **different type of input**. | **BJT**s and **FET**s perform **similar** functions, but with a **different type of input**. | ||
Both kinds of transistors are devices that control the current flowing through them and can be used as digital switches or analog amplifiers. | Both kinds of transistors are devices that control the current flowing through them and can be used as digital switches or analog amplifiers. | ||
- | // FIXME Advice some usual refs to play with // | ||
In the **digital case**, the circuit around the transistor is designed so the input signal (current for a BJT or voltage for a FET) is large enough to turn on the transistor much more than the actual needed output current, or small enough to turn off the transistor completely. | In the **digital case**, the circuit around the transistor is designed so the input signal (current for a BJT or voltage for a FET) is large enough to turn on the transistor much more than the actual needed output current, or small enough to turn off the transistor completely. | ||
Line 325: | Line 323: | ||
{{ ::neonking:opamptransistorlevel_colored.png?direct&300 |}} | {{ ::neonking:opamptransistorlevel_colored.png?direct&300 |}} | ||
- | //FIXME Advice some usual refs like MCP6004 or TL072 to play with // | + | **TL072/TL074/MCP6004** are some refs of Opamps used in MIDIbox Designs |
It's represented in schematics by it's Symbol | It's represented in schematics by it's Symbol | ||
Line 369: | Line 367: | ||
{{ ::neonking:oscillator.jpg?direct&500 |}} | {{ ::neonking:oscillator.jpg?direct&500 |}} | ||
- | //FIXME Find a SIN alike circuitry to be redrawn// | ||
Line 416: | Line 412: | ||
=====11 - Going Further===== | =====11 - Going Further===== | ||
__Theory__ | __Theory__ | ||
- | https://en.wikipedia.org/wiki/Fast_Fourier_transform | + | * [[https://en.wikipedia.org/wiki/Operational_amplifier|Wikipedia Operational Amplifier]] |
- | + | * [[https://en.wikipedia.org/wiki/RLC_circuit|Wikipedia RLC Circuits]] | |
- | https://en.wikipedia.org/wiki/RLC_circuit | + | * [[https://en.wikipedia.org/wiki/Transistor|Wikipedia Transistor]] |
- | + | * [[https://en.wikipedia.org/wiki/Vacuum_tube|Wikipedia Vacuum Tube]] | |
- | https://en.wikipedia.org/wiki/Transistor | + | * [[https://en.wikipedia.org/wiki/Fast_Fourier_transform|Wikipedia FFT]] |
- | https://en.wikipedia.org/wiki/Vacuum_tube | + | |
- | https://en.wikipedia.org/wiki/Integrated_circuit | + | |
- | https://en.wikipedia.org/wiki/Operational_amplifier | + | |
__Practical__ | __Practical__ | ||
- | http://sound.westhost.com/articles.htm | + | * [[http://sound.westhost.com/articles.htm|Elliott Sound Products]] |
- | + | * [[http://www.electronics-lab.com/|Open Source Electronic projects]] | |
- | http://www.electronics-tutorials.ws/ | + | * [[http://www.electronics-tutorials.ws/|Electronic tutorials]] |
- | + | * [[http://www.discovercircuits.com/|DiscoverCircuits Archive]] | |
- | - French - http://www.sonelec-musique.com/electronique_realisations.html | + | |
- | //FIXME replace the last link by an english equivalent archive of basic Audio Circuitry, Power supplies etc// | + | |
