enc_4_4
Differences
Both sides previous revisionPrevious revisionNext revision | Previous revision | ||
enc_4_4 [2018/03/06 18:45] – [Dimensions] latigid_on | enc_4_4 [2018/03/06 21:10] (current) – old revision restored (2018/03/05 22:31) latigid_on | ||
Line 1: | Line 1: | ||
- | Combination of 0.96" SSD1306 OLEDs and switches for an [[http:// | + | Encoders illuminated with WS2812 LEDs |
===== Schematic ===== | ===== Schematic ===== | ||
+ | Power input is +5V via a 3-pin 100mil connector (or Molex) and a Schottky diode. The value of electrolytic capacitor C1 is not critical. | ||
+ | The pLED chain enters via J2:pin 6 and resistor R1. The resistor should be replaced with a wire link for each additional module (i.e. only the first in the chain gets a resistor, the remainder stuffed with wire links). The serial chain then follows a snake pattern to J3, where additional pLED modules may be connected. The LED ID matches the capacitor name. The RC (R2, C18) end termination shouldn' | ||
+ | Encoders are arranged in columns with outputs on J4--7. The top encoder (EN1/5/9/13 uses pins 10/9, the second (EN2/ | ||
Line 11: | Line 15: | ||
- | ===== BOM v1.0 ===== | + | ===== BOM v1.1 ===== |
- | ^ Type ^ Part ^ Value ^ | + | |
- | |Caps | + | |
- | | | C26 | DNF | | + | |
- | | | C29 | 10uF polarised | | + | |
- | |Encoder | EN1 | 12mm | | + | |
- | | | EN2 | 12mm | | + | |
- | |Header | + | |
- | | | J2 | +5V | | + | |
- | | | J5 | PINHD-2X54WALL | | + | |
- | |OLEDs | + | |
- | | | LCD2 | 0.96_OLED | | + | |
- | | | LCD3 | 0.96_OLED | | + | |
- | | | LCD4 | 0.96_OLED | | + | |
- | |Resistors | R3 | DNF | | + | |
- | | | R4 | DNF | | + | |
- | | | R7 | DNF | | + | |
- | | | R9 | 2k2 | | + | |
- | |Switches | S1(A) | DT6 or 6mm | | + | |
- | | | S2(A) | DT6 or 6mm | | + | |
- | | | S3(A) | DT6 or 6mm | | + | |
- | | | S4(A) | DT6 or 6mm | | + | |
- | | | S5(A) | DT6 or 6mm | | + | |
- | | | S6(A) | DT6 or 6mm | | + | |
+ | ^Type | ||
+ | ^resistors^ | ||
+ | ^capacitors^ | ||
+ | | |16|100n|1206|C2-17| | ||
+ | | |1|100-1000u|electrolytic 3,5-6|C1| | ||
+ | ^diodes^ | ||
+ | | |1|1N5187|DO41-7.6|D1| | ||
+ | | |16|WS2812B|5050|programmable LEDs| | ||
+ | ^encoders^ | ||
+ | | |16|clear shaft 12mm encoders| |EN1--16| | ||
+ | ^headers^ | ||
+ | | |6| |2*5 (shrouded) THT|J2-5|can use DIL 100mil breakaway header strips| | ||
+ | | |1| |1X03_SMALL|J1| can use Molex 22-23-2031| | ||
+ | ^misc^ | ||
+ | | |16| |spacer pieces| |optional | | ||
Line 43: | Line 38: | ||
===== Versions ===== | ===== Versions ===== | ||
- | v1.0: first release | + | v1.0: errata: J4--7 have no connection to ground. J1-3 do carry ground, so it isn't a problem if the DIN modules share the same power rail. |
===== Assembly ===== | ===== Assembly ===== | ||
- | Decide on the configuration to be used. Any combination of switches, | + | 1206 caps should go down first, followed by LEDs. The LEDs should |
- | Only one encoder is wired to the J1 header. If you want to use the EN2 position, wire the legs to the empty EN1 solder points. | + | The encoders should be installed so they can turn freely. If they are tight against |
- | R9 and C29 form the power-on reset for OLEDs. R7 should | + | |
- | The switches accommodate either DT6 or 6mm switches | + | |
- | J2 can supply power if needed. | + | |
Line 61: | Line 50: | ||
==== Interconnections ==== | ==== Interconnections ==== | ||
- | {{:: | + | * J1 is a power header with +5V as marked, middle pin 0V. |
+ | * J2 normally connects to Core J4B (I2C) | ||
+ | * J3 carries the WS2812B chain for additional modules | ||
+ | * J4-7 connect to DINX4 headers | ||
- | J1 is the SCS header, connecting to J10A | ||
- | J2 can provide power as indicated; it is also connected on J5. | + | ===== Dimensions ===== |
- | J5 connects to J15 on the Core (or equivalent) | + | {{: |
- | ===== Dimensions ===== | + | |
- | {{ :scsoled:doku.zip |}} | + | {{ :encs:encs_dxf.zip }} |
===== License ===== | ===== License ===== | ||
enc_4_4.txt · Last modified: 2018/03/06 21:10 by latigid_on
