enc_4_4
SCS OLED module
Combination of 0.96“ SSD1306 OLEDs and switches for an SCS
Schematic
BOM v1.0
Type Part Value
Caps C25 DNF
C26 DNF
C29 10uF polarised
Encoder EN1 12mm
EN2 12mm
Header J1 PINHD-2X54WALL
J2 +5V
J5 PINHD-2X54WALL
OLEDs LCD1 0.96_OLED
LCD2 0.96_OLED
LCD3 0.96_OLED
LCD4 0.96_OLED
Resistors R3 DNF
R4 DNF
R7 DNF
R9 2k2
Switches S1(A) DT6 or 6mm
S2(A) DT6 or 6mm
S3(A) DT6 or 6mm
S4(A) DT6 or 6mm
S5(A) DT6 or 6mm
S6(A) DT6 or 6mm
Versions
v1.0: first release
Assembly
Decide on the configuration to be used. Any combination of switches, encoders or OLEDs is possible if they fit.
Only one encoder is wired to the J1 header. If you want to use the EN2 position, wire the legs to the empty EN1 solder points.
R9 and C29 form the power-on reset for OLEDs. R7 should not be installed. R3/C25/R4/C26 form a termination shunt for OLED data lines. They shouldn't be required.
The switches accommodate either DT6 or 6mm switches (obviously only one type!). For DT6 switches, ensure the flat side is aligned with the PCB silkscreen.
J2 can supply power if needed.
Interconnections
J1 is the SCS header, connecting to J10A
J2 can provide power as indicated; it is also connected on J5.
J5 connects to J15 on the Core (or equivalent)
Dimensions
License
enc_4_4.1520361896.txt.gz · Last modified: 2018/03/06 18:44 by latigid_on
