envelope-follower-bissel-based [2021/01/05 21:32] phatline [Kicad Files & Production Files] |
envelope-follower-bissel-based [2021/01/22 02:06] phatline [Envelope Follower] |
Line 2: | Line 2: | ||
based on Harry Bissel\\ | based on Harry Bissel\\ | ||
a SMD Variant, ready for Pick and Place\\ | a SMD Variant, ready for Pick and Place\\ | ||
+ | open-hardware, all Kicad-Files, and Gerbers are includet!\\ | ||
{{:phatline:ENV-Follower-3D-rotate.png?500|}}\\ | {{:phatline:ENV-Follower-3D-rotate.png?500|}}\\ | ||
--shown 2 identical boards on one pcb - to save money.. | --shown 2 identical boards on one pcb - to save money.. | ||
Line 52: | Line 53: | ||
[[https://www.mouser.com/tools/part-list-import.aspx|copy list below, and paste in this link, you will need to order the project 2 times since 2PCBs are on 1PCB]]\\ | [[https://www.mouser.com/tools/part-list-import.aspx|copy list below, and paste in this link, you will need to order the project 2 times since 2PCBs are on 1PCB]]\\ | ||
583-FM4002|2\\ | 583-FM4002|2\\ | ||
- | 490-SJ1-3535NG|3\\ | + | 490-SJ1-3535NG-GR|3\\ |
523-G821EU210AAL10Y|1\\ | 523-G821EU210AAL10Y|1\\ | ||
650-MINISMDC014F-2|2\\ | 650-MINISMDC014F-2|2\\ | ||
Line 60: | Line 61: | ||
652-PTV09A3020FB104|1\\ | 652-PTV09A3020FB104|1\\ | ||
- | when making 10PCBs this make a total of **53,58€** incl Shipping which is free above 50€!\\ | + | for prototyping i ordered:\\ |
+ | **490-SJ1-3535NG-GR** instead of **490-SJ1-3535NG** because it is out of stock - so **GREEN sockets** for now!\\ | ||
+ | when making 10PCBs this make a total of ** 69,83€** incl Shipping/VAT which is free above 50€!\\ | ||
There are 2 SOICs that have to get Handsoldered, i have done this before and its easy!\\ | There are 2 SOICs that have to get Handsoldered, i have done this before and its easy!\\ | ||
{{:phatline:env-follower-handsolder.png?500|}}\\ | {{:phatline:env-follower-handsolder.png?500|}}\\ | ||
+ | the actual Picture is this | ||
+ | {{:phatline:env-follower-3d-buttom.png?500|}}\\ | ||
===== Overall Material Costs ===== | ===== Overall Material Costs ===== | ||
- | PCB:**42,44€ +** MouserParts:**53,58** = 96,02€ **/ 10** PCBs **= 9,602€**\\ | + | PCB:**42,44€ +** MouserParts:** 69,83** = 111,46€ **/ 10** PCBs **= 11,14€ a PCB**\\ |
(where half off work is done by pick and place machine!)\\ | (where half off work is done by pick and place machine!)\\ | ||
Line 72: | Line 78: | ||
Shematic, Board, Gerber, Pick and Place and Booms, ready for Pick and Place!\\ | Shematic, Board, Gerber, Pick and Place and Booms, ready for Pick and Place!\\ | ||
---at the moment untestet, since i order the project just now!\\ | ---at the moment untestet, since i order the project just now!\\ | ||
+ | as Example what you see if you got thru the ordering process:\\ | ||
+ | {{:phatline:ENV-Follower-JLPCB-Job.png?700|}}\\ | ||
+ | {{:phatline:ENV-Follower-JLPCB-Invoice.png?700|}}\\ | ||
===== Shematic ===== | ===== Shematic ===== | ||
{{:phatline:ENV-Follower-Shematic.png?800|}}\\ | {{:phatline:ENV-Follower-Shematic.png?800|}}\\ | ||
===== To Do ===== | ===== To Do ===== | ||
- | experiment with the Smooting CAP, i already implimented a Jumper which add a second Capacitor to "double" the capacity... i took 220+220nF, but maybe it is better to use 100+220nF?\\ | + | frontplate\\ |
- | experiment with the Frequency Pot which is a lin10K + 2K Serial Resistor which gives a range of 2K-12K - really dont know what value spectrum we need here!\\ | + | Debugging First Version\\ |
- | adding some Jumpers to break the circuit for debugging or measurement\\ | + | **experiment with the Smooting CAP:** a Header is connected paralell to a integrated 100nF Cap, connect there a CAP to encrease the smoothing\\ |
- | frontplate, Debugging First Version\\ | + | **experiment with the Frequency Pot:** a lin10K + 1K internal Serial Resistor which gives a range of 1K-12K - i also made a Header here, which you can bridge then you have 1-12K, or you put a resistor there for example a 5K, then you will get a range from 6-16K... \\ |
+ | I addet some Jumpers to break the circuit for debugging or measurement\\ | ||
+ | Modding **Headers/Jumpers:**\\ | ||
+ | {{:phatline:ENV-Follower-3D-top.png?800|}}\\ | ||
===== Resources ===== | ===== Resources ===== | ||
[[https://www.muffwiggler.com/forum/viewtopic.php?f=17&t=109067#p1511975|muffwiggler-topic]]\\ | [[https://www.muffwiggler.com/forum/viewtopic.php?f=17&t=109067#p1511975|muffwiggler-topic]]\\ | ||
Line 88: | Line 101: | ||
[[https://www.muffwiggler.com/forum/userpix2/10917_bom_1.jpg|THT-PCB-BOM]]\\ | [[https://www.muffwiggler.com/forum/userpix2/10917_bom_1.jpg|THT-PCB-BOM]]\\ | ||
[[https://www.muffwiggler.com/forum/userpix2/32564_scr01_2.png|Haralds-Hi-Clock-Measurements]]\\ | [[https://www.muffwiggler.com/forum/userpix2/32564_scr01_2.png|Haralds-Hi-Clock-Measurements]]\\ | ||
+ | I give this links because it is the source: but i cant recommend that forum! (deletes of posts, shitstorm, non constructive posts...) | ||
====== Community users working on it ====== | ====== Community users working on it ====== | ||
* **[[Phatline]]** = Programming, Documentation...\\ | * **[[Phatline]]** = Programming, Documentation...\\ |
