Both sides previous revision Previous revision | Next revision Both sides next revision | ||
envelope-follower-bissel-based [2021/01/05 22:59] phatline [To Do] |
envelope-follower-bissel-based [2021/01/05 23:00] phatline |
Line 88: | Line 88: | ||
Debugging First Version\\ | Debugging First Version\\ | ||
**experiment with the Smooting CAP:** a Header is connected paralell to a integrated 100nF Cap, connect there a CAP to encrease the smoothing\\ | **experiment with the Smooting CAP:** a Header is connected paralell to a integrated 100nF Cap, connect there a CAP to encrease the smoothing\\ | ||
- | experiment with the Frequency Pot which is a lin10K + 1K Serial Resistor which gives a range of 1K-12K - i also made a Header here, which you can bridge then you have 1-12K, or you put a resistor there for example a 5K, then you will get a range from 6-16K... \\ | + | **experiment with the Frequency Pot:** a lin10K + 1K internal Serial Resistor which gives a range of 1K-12K - i also made a Header here, which you can bridge then you have 1-12K, or you put a resistor there for example a 5K, then you will get a range from 6-16K... \\ |
I addet some Jumpers to break the circuit for debugging or measurement\\ | I addet some Jumpers to break the circuit for debugging or measurement\\ | ||
