etching_pcb [2016/07/18 11:16] psykhaze [Single Side] |
etching_pcb [2016/07/23 16:11] psykhaze [Toner Transfer] |
Line 6: | Line 6: | ||
===== Toner Transfer ===== | ===== Toner Transfer ===== | ||
- | A Simple and costless method Flow to make proto PCB based upon **Laser Printed Toner** and **Laminator/Ironer**. | + | A Simple and costless method Flow to make proto PCB based upon **Laser Printed Negative** and **Laminator/Ironer**. |
- | ==== Single Side ==== | ||
- | {{youtube>whIsDraCf3I?large}} | ||
- | {{youtube>wKEe3otWstM?large}} | ||
+ | **The laminator need a hack** to increase heating temperature , but it's a more precise way ta make the transfer than ironer. | ||
+ | ==== Simple side Transfer + Etching ==== | ||
+ | {{youtube>wKEe3otWstM?medium}} | ||
+ | ==== Double side Transfer + Etching ==== | ||
+ | {{youtube>dLZoH_jXYRU?medium}} | ||
+ | ==== Laminator Transfer ==== | ||
- | ==== Direct Laser Printing ==== | + | === Laminator hack === |
- | {{youtube>VY-7hQ6ocx8?large}} | + | {{::neonking:laminatorhack.jpg?direct&500 |}} |
+ | === Method Video === | ||
+ | {{youtube>whIsDraCf3I?medium}} | ||
+ | ==== Direct Laser Transfer==== | ||
+ | {{youtube>VY-7hQ6ocx8?medium}} | ||
===== Isolation Milling ===== | ===== Isolation Milling ===== | ||
Line 20: | Line 32: | ||
A method that uses **CNC** to engrave around paths to isolate them from rest of PCB board | A method that uses **CNC** to engrave around paths to isolate them from rest of PCB board | ||
- | {{youtube>na9-USi_hZQ?large}} | + | {{youtube>na9-USi_hZQ?medium}} |
