etching_pcb [2016/07/23 16:09] psykhaze [Laminator Transfer] |
etching_pcb [2016/07/23 16:11] psykhaze [Toner Transfer] |
Line 8: | Line 8: | ||
A Simple and costless method Flow to make proto PCB based upon **Laser Printed Negative** and **Laminator/Ironer**. | A Simple and costless method Flow to make proto PCB based upon **Laser Printed Negative** and **Laminator/Ironer**. | ||
- | The laminator need a hack to increase heating temperature , but it's a more precise way ta make the transfer than ironer. | + | \\ |
+ | **The laminator need a hack** to increase heating temperature , but it's a more precise way ta make the transfer than ironer. | ||
==== Simple side Transfer + Etching ==== | ==== Simple side Transfer + Etching ==== | ||
Line 17: | Line 18: | ||
==== Laminator Transfer ==== | ==== Laminator Transfer ==== | ||
+ | === Laminator hack === | ||
{{::neonking:laminatorhack.jpg?direct&500 |}} | {{::neonking:laminatorhack.jpg?direct&500 |}} | ||
+ | === Method Video === | ||
{{youtube>whIsDraCf3I?medium}} | {{youtube>whIsDraCf3I?medium}} | ||
