etching_pcb [2016/07/23 16:10] psykhaze [Laminator Transfer] |
etching_pcb [2016/07/23 16:13] psykhaze [Etching PCB DIY] |
Line 2: | Line 2: | ||
Before sending some PCB to get pro made (really the best time proof solution) it is useful to debug it by etching it yourself | Before sending some PCB to get pro made (really the best time proof solution) it is useful to debug it by etching it yourself | ||
===== Toner Transfer ===== | ===== Toner Transfer ===== | ||
- | A Simple and costless method Flow to make proto PCB based upon **Laser Printed Negative** and **Laminator/Ironer**. | + | A Simple and costless method Flow to make proto PCB based upon **Laser Printed Negative** and **Laminator or Ironer**. |
- | The laminator need a hack to increase heating temperature , but it's a more precise way ta make the transfer than ironer. | + | \\ |
+ | **The laminator need a hack** to increase heating temperature , but it's a more precise way ta make the transfer than ironer. | ||
==== Simple side Transfer + Etching ==== | ==== Simple side Transfer + Etching ==== | ||
Line 19: | Line 19: | ||
=== Laminator hack === | === Laminator hack === | ||
{{::neonking:laminatorhack.jpg?direct&500 |}} | {{::neonking:laminatorhack.jpg?direct&500 |}} | ||
