Both sides previous revision Previous revision | Next revision Both sides next revision | ||
etching_pcb [2016/07/23 16:10] psykhaze [Laminator Transfer] |
etching_pcb [2016/07/23 16:11] psykhaze [Toner Transfer] |
Line 8: | Line 8: | ||
A Simple and costless method Flow to make proto PCB based upon **Laser Printed Negative** and **Laminator/Ironer**. | A Simple and costless method Flow to make proto PCB based upon **Laser Printed Negative** and **Laminator/Ironer**. | ||
- | The laminator need a hack to increase heating temperature , but it's a more precise way ta make the transfer than ironer. | + | \\ |
+ | ***The laminator need a hack** to increase heating temperature , but it's a more precise way ta make the transfer than ironer. | ||
==== Simple side Transfer + Etching ==== | ==== Simple side Transfer + Etching ==== |
