fadercore_-_vlr-3x8but [2014/07/27 22:10] novski |
fadercore_-_vlr-3x8but [2014/07/28 07:31] novski |
Line 44: | Line 44: | ||
Project Order Basket on Mouser: [[http://www.mouser.com/ProjectManager/ProjectDetail.aspx?AccessID=1f42b04e6d]] | Project Order Basket on Mouser: [[http://www.mouser.com/ProjectManager/ProjectDetail.aspx?AccessID=1f42b04e6d]] | ||
- | The PCB is available under: [[]] | + | The PCB is available under: [[https://www.vlrlab.com/home/20-3x8but.html]] |
Line 62: | Line 62: | ||
==== Test it in MIOS ==== | ==== Test it in MIOS ==== | ||
- | To make it work with MIOS .NGC File we need to know how the shift-registers are connected. | + | To make it work with MIOS .NGC File we need to know how the shift-registers are connected.\\ |
**Inputs:**\\ | **Inputs:**\\ | ||
- | 1# Encoder 1-4\\ | + | 1# Switch Columns 1-8\\ |
- | 2# Encoder 5-8\\ | + | \\ |
- | 3# Encoder Button 1-8\\ | + | |
**Outputs:**\\ | **Outputs:**\\ | ||
- | 1# RED Shaft LED 1-8\\ | + | 1# ROW Outputs 1-6\\ |
- | 2# GREEN shaft LED 1-8\\ | + | 2# RED LEDs 1-8\\ |
- | 3# BLUE shaft LED 1-8\\ | + | 3# GREEN LEDs 1-8\\ |
- | 4# LED Ring Row 1-8\\ | + | 4# BLUE LEDs 1-8\\ |
- | 5# LED Ring Selct 1-8\\ | + | \\ |
- | 6# LED Ring Select 9-11\\ | + | Assuming that the VLR-3x8But is the first device on the chain of J8/9 we need to configure it like this:\\ |
- | Assuming that the VLR-8Enc is the first device on the chain of J8/9 we need to configure it like this: | + | |
RESET_HW\\ | RESET_HW\\ | ||
Line 131: | Line 127: | ||
Im using my VLR-8oDisp board to show the Values of every item. You can change it to any other type of Display-setting... lcd_pos=6:1:5 {6=Display number : 1= X-axis : 5= Y-Axis (row)} | Im using my VLR-8oDisp board to show the Values of every item. You can change it to any other type of Display-setting... lcd_pos=6:1:5 {6=Display number : 1= X-axis : 5= Y-Axis (row)} | ||
+ | For any Comment or Question: Forum Thread??? |
