fadercore_-_vlr-8enc [2014/07/26 14:28] novski |
fadercore_-_vlr-8enc [2014/07/27 21:23] novski |
Line 1: | Line 1: | ||
- | ====== Fadercore ====== | + | [[fadercore_-_fadermodule_for_audio_daw|Fadercore]] |
Standard 220mm wide modules | Standard 220mm wide modules | ||
Line 17: | Line 17: | ||
==== BOM ==== | ==== BOM ==== | ||
- | BIll of Material | + | BIll of Material |
- | Qty Value Device Package | + | |
- | * 2 ML10 ML10 | + | |
- | * 2 ULN2803SO18W SO18W | + | |
- | * 3 100n C-EU025-024X044 C025-024X044 | + | |
- | * 6 100nF C-EU025-024X044 C025-024X044 | + | |
- | * 6 10k 4306R SIL6 | + | |
- | * 4 220 4816P-1SOIC16W SOIC16W | + | |
- | * 3 220 R-EU_0204/7 0204/7 | + | |
- | * 3 74HC165N 74HC165NSO16D SO16D | + | |
- | * 3 74HC595 74HC595SO16D SO16D | + | |
- | * 8 BOURNS_PEL12T BOURNS_PEL12T_11-LED-RING PEL12T_11-LED-RING | + | |
- | * 3 TPIC6B595 TPIC6B595SO20W SO20W | + | |
Allways look for the cheapest seller, the Price may vary heavy!!! | Allways look for the cheapest seller, the Price may vary heavy!!! | ||
Line 38: | Line 25: | ||
I was fascinated about the RGB Shaft of this Encoder so i developed all opon this nice piece. | I was fascinated about the RGB Shaft of this Encoder so i developed all opon this nice piece. | ||
- | Its not the cheapest but i sell them for a reasonable price. | + | Its not the cheapest but i sell them for a reasonable price. |
+ | **And its still possible to use a non Illuminated Encoder.** | ||
== The other Materials: Mouser == | == The other Materials: Mouser == | ||
- | * 2x10pin Header, 517-30310-6002 | + | * 2x10pin Header, 517-30310-6002 |
- | * 1xResistor Array 220Ohm SMD, | + | * 2xULN2803, 595-ULN2803ADWR |
- | * 1x74HC595 SMD, | + | * 9x100nF,594-K104K15X7RF53K2 |
- | * 2x100nF, | + | * 6x10k, 774-77061103P |
+ | * 4x220, 652-4816P-T1LF-220 | ||
+ | * 3x220, 660-MF1/2LCT52R221J | ||
+ | * 3x74HC165D, 771-HC165D652 | ||
+ | * 3x74HC595D, 771-74HC595D | ||
+ | * 3xTPIC6B595, because the MOQ is 250 i deliver them for you with the PCB. | ||
+ | * 88xLED RED, 604-WP3A8HD | ||
+ | * 88xLED holder 6mm Height, 749-ELM-5-6MM | ||
- | Project Order Basket on Mouser: [[]] | + | Project Order Basket on Mouser: [[http://www.mouser.com/ProjectManager/ProjectDetail.aspx?AccessID=a6dbae9ab7]] |
+ | The PCB is available under: [[http://vlrlab.com/lang/17-8enc.html]] | ||
+ | * 8 Encoder, 652-PEL12T4226FS1024 **not on Projectlist because i deliver cheaper and with cap included..** | ||
+ | The Encoder on VLRlabs.com [[https://www.vlrlab.com/encoder/13-bourns-rgb-led-encoder.html]] | ||
- | The PCB is available under: [[https://vlrlab.com/pcb/10-8-odisplay.html]] | ||
==== How to get Started ==== | ==== How to get Started ==== | ||
+ | If its your first SMD soldering you can follow this on t1:58 : http://www.youtube.com/watch?v=5uiroWBkdFY | ||
+ | I recommend to not buy solder paste, instead buy some flux-paste like this on Mouser: 590-8341-10ML | ||
==== Prepare the PCB ==== | ==== Prepare the PCB ==== | ||
+ | Start with the SMD parts and then go on the the conventional parts also on the Bottom side. Don't forget the R11,12,13. | ||
+ | Then go on with the Topside and the LEDs before soldering the Encoder as last. | ||
+ | Check the Connections with a Lens. | ||
==== Prepare the Connection ==== | ==== Prepare the Connection ==== | ||
+ | Connect the core on J8/9 to J1 of the VLR-8Enc board. | ||
==== Test it in MIOS ==== | ==== Test it in MIOS ==== | ||
+ | To make it work with MIOS .NGC File we need to know how the shift-registers are connected. | ||
+ | **Inputs:**\\ | ||
+ | 1# Encoder 1-4\\ | ||
+ | 2# Encoder 5-8\\ | ||
+ | 3# Encoder Button 1-8\\ | ||
+ | **Outputs:**\\ | ||
+ | 1# RED Shaft LED 1-8\\ | ||
+ | 2# GREEN shaft LED 1-8\\ | ||
+ | 3# BLUE shaft LED 1-8\\ | ||
+ | 4# LED Ring Row 1-8\\ | ||
+ | 5# LED Ring Selct 1-8\\ | ||
+ | 6# LED Ring Select 9-11\\ | ||
+ | Assuming that the VLR-8Enc is the first device on the chain of J8/9 we need to configure it like this: | ||
+ | RESET_HW\\ | ||
+ | LCD "%C"\\ | ||
+ | # Encoder configuration\\ | ||
+ | ENC n= 1 sr=1 pins=0:1 type=detented2\\ | ||
+ | ENC n= 2 sr=1 pins=2:3 type=detented2\\ | ||
+ | ENC n= 3 sr=1 pins=4:5 type=detented2\\ | ||
+ | ENC n= 4 sr=1 pins=6:7 type=detented2\\ | ||
+ | ENC n= 5 sr=2 pins=0:1 type=detented2\\ | ||
+ | ENC n= 6 sr=2 pins=2:3 type=detented2\\ | ||
+ | ENC n= 7 sr=2 pins=4:5 type=detented2\\ | ||
+ | ENC n= 8 sr=2 pins=6:7 type=detented2\\ | ||
+ | # LEDring configuration\\ | ||
+ | DOUT_MATRIX n= 1 rows=16 mirrored_row=0 inverted_sel=1 sr_dout_sel1= 4 sr_dout_sel2= 0 sr_dout_r1= 5 sr_dout_r2= 6\\ | ||
+ | # Encoder events\\ | ||
+ | EVENT_ENC id= 1 fwd_id=LED_MATRIX:1 type=CC chn= 1 cc= 24 lcd_pos=1:1:2 label="^std_enc" LED_MATRIX_PATTERN=2\\ | ||
+ | EVENT_ENC id= 2 fwd_id=LED_MATRIX:2 type=CC chn= 1 cc= 25 lcd_pos=2:1:2 label="^std_enc" LED_MATRIX_PATTERN=2\\ | ||
+ | EVENT_ENC id= 3 fwd_id=LED_MATRIX:3 type=CC chn= 1 cc= 26 lcd_pos=3:1:2 label="^std_enc" LED_MATRIX_PATTERN=2\\ | ||
+ | EVENT_ENC id= 4 fwd_id=LED_MATRIX:4 type=CC chn= 1 cc= 27 lcd_pos=4:1:2 label="^std_enc" LED_MATRIX_PATTERN=2\\ | ||
+ | EVENT_ENC id= 5 fwd_id=LED_MATRIX:5 type=CC chn= 1 cc= 28 lcd_pos=5:1:2 label="^std_enc" LED_MATRIX_PATTERN=2\\ | ||
+ | EVENT_ENC id= 6 fwd_id=LED_MATRIX:6 type=CC chn= 1 cc= 29 lcd_pos=6:1:2 label="^std_enc" LED_MATRIX_PATTERN=2\\ | ||
+ | EVENT_ENC id= 7 fwd_id=LED_MATRIX:7 type=CC chn= 1 cc= 30 lcd_pos=7:1:2 label="^std_enc" LED_MATRIX_PATTERN=2\\ | ||
+ | EVENT_ENC id= 8 fwd_id=LED_MATRIX:8 type=CC chn= 1 cc= 31 lcd_pos=8:1:2 label="^std_enc" LED_MATRIX_PATTERN=2\\ | ||
+ | # Encoder Buttons\\ | ||
+ | EVENT_BUTTON id=117 hw_id=17 fwd_id=LED:8 type=cc chn=1 cc=15 range=0:127 button_mode=OnOff lcd_pos=1:1:3 label="R^std_btn"\\ | ||
+ | EVENT_BUTTON id=117 hw_id=17 fwd_id=LED:16 type=cc chn=1 cc=15 range=0:127 button_mode=OnOff lcd_pos=1:1:4 label="G^std_btn"\\ | ||
+ | EVENT_BUTTON id=117 hw_id=17 fwd_id=LED:24 type=cc chn=1 cc=15 range=0:127 button_mode=OnOff lcd_pos=1:1:5 label="B^std_btn"\\ | ||
+ | EVENT_BUTTON id=118 hw_id=18 fwd_id=LED:7 type=cc chn=1 cc=15 range=0:127 button_mode=OnOff lcd_pos=2:1:3 label="R^std_btn"\\ | ||
+ | EVENT_BUTTON id=118 hw_id=18 fwd_id=LED:15 type=cc chn=1 cc=15 range=0:127 button_mode=OnOff lcd_pos=2:1:4 label="G^std_btn"\\ | ||
+ | EVENT_BUTTON id=118 hw_id=18 fwd_id=LED:23 type=cc chn=1 cc=15 range=0:127 button_mode=OnOff lcd_pos=2:1:5 label="B^std_btn"\\ | ||
+ | EVENT_BUTTON id=119 hw_id=19 fwd_id=LED:6 type=cc chn=1 cc=15 range=0:127 button_mode=OnOff lcd_pos=3:1:3 label="R^std_btn"\\ | ||
+ | EVENT_BUTTON id=119 hw_id=19 fwd_id=LED:14 type=cc chn=1 cc=15 range=0:127 button_mode=OnOff lcd_pos=3:1:4 label="G^std_btn"\\ | ||
+ | EVENT_BUTTON id=119 hw_id=19 fwd_id=LED:22 type=cc chn=1 cc=15 range=0:127 button_mode=OnOff lcd_pos=3:1:5 label="B^std_btn"\\ | ||
+ | EVENT_BUTTON id=120 hw_id=20 fwd_id=LED:5 type=cc chn=1 cc=15 range=0:127 button_mode=OnOff lcd_pos=4:1:3 label="R^std_btn"\\ | ||
+ | EVENT_BUTTON id=120 hw_id=20 fwd_id=LED:13 type=cc chn=1 cc=15 range=0:127 button_mode=OnOff lcd_pos=4:1:4 label="G^std_btn"\\ | ||
+ | EVENT_BUTTON id=120 hw_id=20 fwd_id=LED:21 type=cc chn=1 cc=15 range=0:127 button_mode=OnOff lcd_pos=4:1:5 label="B^std_btn"\\ | ||
+ | EVENT_BUTTON id=121 hw_id=21 fwd_id=LED:4 type=cc chn=1 cc=15 range=0:127 button_mode=OnOff lcd_pos=5:1:3 label="R^std_btn"\\ | ||
+ | EVENT_BUTTON id=121 hw_id=21 fwd_id=LED:12 type=cc chn=1 cc=15 range=0:127 button_mode=OnOff lcd_pos=5:1:4 label="G^std_btn"\\ | ||
+ | EVENT_BUTTON id=121 hw_id=21 fwd_id=LED:20 type=cc chn=1 cc=15 range=0:127 button_mode=OnOff lcd_pos=5:1:5 label="B^std_btn"\\ | ||
+ | EVENT_BUTTON id=122 hw_id=22 fwd_id=LED:3 type=cc chn=1 cc=15 range=0:127 button_mode=OnOff lcd_pos=6:1:3 label="R^std_btn"\\ | ||
+ | EVENT_BUTTON id=122 hw_id=22 fwd_id=LED:11 type=cc chn=1 cc=15 range=0:127 button_mode=OnOff lcd_pos=6:1:4 label="G^std_btn"\\ | ||
+ | EVENT_BUTTON id=122 hw_id=22 fwd_id=LED:19 type=cc chn=1 cc=15 range=0:127 button_mode=OnOff lcd_pos=6:1:5 label="B^std_btn"\\ | ||
+ | EVENT_BUTTON id=123 hw_id=23 fwd_id=LED:2 type=cc chn=1 cc=15 range=0:127 button_mode=OnOff lcd_pos=7:1:3 label="R^std_btn"\\ | ||
+ | EVENT_BUTTON id=123 hw_id=23 fwd_id=LED:10 type=cc chn=1 cc=15 range=0:127 button_mode=OnOff lcd_pos=7:1:4 label="G^std_btn"\\ | ||
+ | EVENT_BUTTON id=123 hw_id=23 fwd_id=LED:18 type=cc chn=1 cc=15 range=0:127 button_mode=OnOff lcd_pos=7:1:5 label="B^std_btn"\\ | ||
+ | EVENT_BUTTON id=124 hw_id=24 fwd_id=LED:1 type=cc chn=1 cc=15 range=0:127 button_mode=OnOff lcd_pos=8:1:3 label="R^std_btn"\\ | ||
+ | EVENT_BUTTON id=124 hw_id=24 fwd_id=LED:9 type=cc chn=1 cc=15 range=0:127 button_mode=OnOff lcd_pos=8:1:4 label="G^std_btn"\\ | ||
+ | EVENT_BUTTON id=124 hw_id=24 fwd_id=LED:17 type=cc chn=1 cc=15 range=0:127 button_mode=OnOff lcd_pos=8:1:5 label="B^std_btn"\\ | ||
+ | LED_MATRIX_PATTERN n=2 pos= 0 pattern=1111110000000000\\ | ||
+ | LED_MATRIX_PATTERN n=2 pos= 1 pattern=0111110000000000\\ | ||
+ | LED_MATRIX_PATTERN n=2 pos= 2 pattern=0011110000000000\\ | ||
+ | LED_MATRIX_PATTERN n=2 pos= 3 pattern=0001110000000000\\ | ||
+ | LED_MATRIX_PATTERN n=2 pos= 4 pattern=0001110000000000\\ | ||
+ | LED_MATRIX_PATTERN n=2 pos= 5 pattern=0000110000000000\\ | ||
+ | LED_MATRIX_PATTERN n=2 pos= 6 pattern=0000010000000000\\ | ||
+ | LED_MATRIX_PATTERN n=2 pos= M pattern=0000111000010000\\ | ||
+ | LED_MATRIX_PATTERN n=2 pos= 8 pattern=0000010000000000\\ | ||
+ | LED_MATRIX_PATTERN n=2 pos= 9 pattern=0000011000000000\\ | ||
+ | LED_MATRIX_PATTERN n=2 pos=10 pattern=0000011000000000\\ | ||
+ | LED_MATRIX_PATTERN n=2 pos=11 pattern=0000011100000000\\ | ||
+ | LED_MATRIX_PATTERN n=2 pos=12 pattern=0000011110000000\\ | ||
+ | LED_MATRIX_PATTERN n=2 pos=13 pattern=0000011110000000\\ | ||
+ | LED_MATRIX_PATTERN n=2 pos=14 pattern=0000011111000000\\ | ||
+ | Im using my VLR-8oDisp board to show the Values of every item. You can change it to any other type of Display-setting... lcd_pos=6:1:5 {6=Display number : 1= X-axis : 5= Y-Axis (row)} |
