fadercore_-_vlr-8enc [2014/07/27 08:15] novski |
fadercore_-_vlr-8enc [2014/07/27 21:23] novski |
Line 1: | Line 1: | ||
- | ====== Fadercore ====== | + | [[fadercore_-_fadermodule_for_audio_daw|Fadercore]] |
Standard 220mm wide modules | Standard 220mm wide modules | ||
Line 66: | Line 66: | ||
==== Test it in MIOS ==== | ==== Test it in MIOS ==== | ||
+ | To make it work with MIOS .NGC File we need to know how the shift-registers are connected. | ||
+ | **Inputs:**\\ | ||
+ | 1# Encoder 1-4\\ | ||
+ | 2# Encoder 5-8\\ | ||
+ | 3# Encoder Button 1-8\\ | ||
+ | **Outputs:**\\ | ||
+ | 1# RED Shaft LED 1-8\\ | ||
+ | 2# GREEN shaft LED 1-8\\ | ||
+ | 3# BLUE shaft LED 1-8\\ | ||
+ | 4# LED Ring Row 1-8\\ | ||
+ | 5# LED Ring Selct 1-8\\ | ||
+ | 6# LED Ring Select 9-11\\ | ||
+ | Assuming that the VLR-8Enc is the first device on the chain of J8/9 we need to configure it like this: | ||
+ | RESET_HW\\ | ||
+ | LCD "%C"\\ | ||
+ | # Encoder configuration\\ | ||
+ | ENC n= 1 sr=1 pins=0:1 type=detented2\\ | ||
+ | ENC n= 2 sr=1 pins=2:3 type=detented2\\ | ||
+ | ENC n= 3 sr=1 pins=4:5 type=detented2\\ | ||
+ | ENC n= 4 sr=1 pins=6:7 type=detented2\\ | ||
+ | ENC n= 5 sr=2 pins=0:1 type=detented2\\ | ||
+ | ENC n= 6 sr=2 pins=2:3 type=detented2\\ | ||
+ | ENC n= 7 sr=2 pins=4:5 type=detented2\\ | ||
+ | ENC n= 8 sr=2 pins=6:7 type=detented2\\ | ||
+ | # LEDring configuration\\ | ||
+ | DOUT_MATRIX n= 1 rows=16 mirrored_row=0 inverted_sel=1 sr_dout_sel1= 4 sr_dout_sel2= 0 sr_dout_r1= 5 sr_dout_r2= 6\\ | ||
+ | # Encoder events\\ | ||
+ | EVENT_ENC id= 1 fwd_id=LED_MATRIX:1 type=CC chn= 1 cc= 24 lcd_pos=1:1:2 label="^std_enc" LED_MATRIX_PATTERN=2\\ | ||
+ | EVENT_ENC id= 2 fwd_id=LED_MATRIX:2 type=CC chn= 1 cc= 25 lcd_pos=2:1:2 label="^std_enc" LED_MATRIX_PATTERN=2\\ | ||
+ | EVENT_ENC id= 3 fwd_id=LED_MATRIX:3 type=CC chn= 1 cc= 26 lcd_pos=3:1:2 label="^std_enc" LED_MATRIX_PATTERN=2\\ | ||
+ | EVENT_ENC id= 4 fwd_id=LED_MATRIX:4 type=CC chn= 1 cc= 27 lcd_pos=4:1:2 label="^std_enc" LED_MATRIX_PATTERN=2\\ | ||
+ | EVENT_ENC id= 5 fwd_id=LED_MATRIX:5 type=CC chn= 1 cc= 28 lcd_pos=5:1:2 label="^std_enc" LED_MATRIX_PATTERN=2\\ | ||
+ | EVENT_ENC id= 6 fwd_id=LED_MATRIX:6 type=CC chn= 1 cc= 29 lcd_pos=6:1:2 label="^std_enc" LED_MATRIX_PATTERN=2\\ | ||
+ | EVENT_ENC id= 7 fwd_id=LED_MATRIX:7 type=CC chn= 1 cc= 30 lcd_pos=7:1:2 label="^std_enc" LED_MATRIX_PATTERN=2\\ | ||
+ | EVENT_ENC id= 8 fwd_id=LED_MATRIX:8 type=CC chn= 1 cc= 31 lcd_pos=8:1:2 label="^std_enc" LED_MATRIX_PATTERN=2\\ | ||
+ | # Encoder Buttons\\ | ||
+ | EVENT_BUTTON id=117 hw_id=17 fwd_id=LED:8 type=cc chn=1 cc=15 range=0:127 button_mode=OnOff lcd_pos=1:1:3 label="R^std_btn"\\ | ||
+ | EVENT_BUTTON id=117 hw_id=17 fwd_id=LED:16 type=cc chn=1 cc=15 range=0:127 button_mode=OnOff lcd_pos=1:1:4 label="G^std_btn"\\ | ||
+ | EVENT_BUTTON id=117 hw_id=17 fwd_id=LED:24 type=cc chn=1 cc=15 range=0:127 button_mode=OnOff lcd_pos=1:1:5 label="B^std_btn"\\ | ||
+ | EVENT_BUTTON id=118 hw_id=18 fwd_id=LED:7 type=cc chn=1 cc=15 range=0:127 button_mode=OnOff lcd_pos=2:1:3 label="R^std_btn"\\ | ||
+ | EVENT_BUTTON id=118 hw_id=18 fwd_id=LED:15 type=cc chn=1 cc=15 range=0:127 button_mode=OnOff lcd_pos=2:1:4 label="G^std_btn"\\ | ||
+ | EVENT_BUTTON id=118 hw_id=18 fwd_id=LED:23 type=cc chn=1 cc=15 range=0:127 button_mode=OnOff lcd_pos=2:1:5 label="B^std_btn"\\ | ||
+ | EVENT_BUTTON id=119 hw_id=19 fwd_id=LED:6 type=cc chn=1 cc=15 range=0:127 button_mode=OnOff lcd_pos=3:1:3 label="R^std_btn"\\ | ||
+ | EVENT_BUTTON id=119 hw_id=19 fwd_id=LED:14 type=cc chn=1 cc=15 range=0:127 button_mode=OnOff lcd_pos=3:1:4 label="G^std_btn"\\ | ||
+ | EVENT_BUTTON id=119 hw_id=19 fwd_id=LED:22 type=cc chn=1 cc=15 range=0:127 button_mode=OnOff lcd_pos=3:1:5 label="B^std_btn"\\ | ||
+ | EVENT_BUTTON id=120 hw_id=20 fwd_id=LED:5 type=cc chn=1 cc=15 range=0:127 button_mode=OnOff lcd_pos=4:1:3 label="R^std_btn"\\ | ||
+ | EVENT_BUTTON id=120 hw_id=20 fwd_id=LED:13 type=cc chn=1 cc=15 range=0:127 button_mode=OnOff lcd_pos=4:1:4 label="G^std_btn"\\ | ||
+ | EVENT_BUTTON id=120 hw_id=20 fwd_id=LED:21 type=cc chn=1 cc=15 range=0:127 button_mode=OnOff lcd_pos=4:1:5 label="B^std_btn"\\ | ||
+ | EVENT_BUTTON id=121 hw_id=21 fwd_id=LED:4 type=cc chn=1 cc=15 range=0:127 button_mode=OnOff lcd_pos=5:1:3 label="R^std_btn"\\ | ||
+ | EVENT_BUTTON id=121 hw_id=21 fwd_id=LED:12 type=cc chn=1 cc=15 range=0:127 button_mode=OnOff lcd_pos=5:1:4 label="G^std_btn"\\ | ||
+ | EVENT_BUTTON id=121 hw_id=21 fwd_id=LED:20 type=cc chn=1 cc=15 range=0:127 button_mode=OnOff lcd_pos=5:1:5 label="B^std_btn"\\ | ||
+ | EVENT_BUTTON id=122 hw_id=22 fwd_id=LED:3 type=cc chn=1 cc=15 range=0:127 button_mode=OnOff lcd_pos=6:1:3 label="R^std_btn"\\ | ||
+ | EVENT_BUTTON id=122 hw_id=22 fwd_id=LED:11 type=cc chn=1 cc=15 range=0:127 button_mode=OnOff lcd_pos=6:1:4 label="G^std_btn"\\ | ||
+ | EVENT_BUTTON id=122 hw_id=22 fwd_id=LED:19 type=cc chn=1 cc=15 range=0:127 button_mode=OnOff lcd_pos=6:1:5 label="B^std_btn"\\ | ||
+ | EVENT_BUTTON id=123 hw_id=23 fwd_id=LED:2 type=cc chn=1 cc=15 range=0:127 button_mode=OnOff lcd_pos=7:1:3 label="R^std_btn"\\ | ||
+ | EVENT_BUTTON id=123 hw_id=23 fwd_id=LED:10 type=cc chn=1 cc=15 range=0:127 button_mode=OnOff lcd_pos=7:1:4 label="G^std_btn"\\ | ||
+ | EVENT_BUTTON id=123 hw_id=23 fwd_id=LED:18 type=cc chn=1 cc=15 range=0:127 button_mode=OnOff lcd_pos=7:1:5 label="B^std_btn"\\ | ||
+ | EVENT_BUTTON id=124 hw_id=24 fwd_id=LED:1 type=cc chn=1 cc=15 range=0:127 button_mode=OnOff lcd_pos=8:1:3 label="R^std_btn"\\ | ||
+ | EVENT_BUTTON id=124 hw_id=24 fwd_id=LED:9 type=cc chn=1 cc=15 range=0:127 button_mode=OnOff lcd_pos=8:1:4 label="G^std_btn"\\ | ||
+ | EVENT_BUTTON id=124 hw_id=24 fwd_id=LED:17 type=cc chn=1 cc=15 range=0:127 button_mode=OnOff lcd_pos=8:1:5 label="B^std_btn"\\ | ||
+ | LED_MATRIX_PATTERN n=2 pos= 0 pattern=1111110000000000\\ | ||
+ | LED_MATRIX_PATTERN n=2 pos= 1 pattern=0111110000000000\\ | ||
+ | LED_MATRIX_PATTERN n=2 pos= 2 pattern=0011110000000000\\ | ||
+ | LED_MATRIX_PATTERN n=2 pos= 3 pattern=0001110000000000\\ | ||
+ | LED_MATRIX_PATTERN n=2 pos= 4 pattern=0001110000000000\\ | ||
+ | LED_MATRIX_PATTERN n=2 pos= 5 pattern=0000110000000000\\ | ||
+ | LED_MATRIX_PATTERN n=2 pos= 6 pattern=0000010000000000\\ | ||
+ | LED_MATRIX_PATTERN n=2 pos= M pattern=0000111000010000\\ | ||
+ | LED_MATRIX_PATTERN n=2 pos= 8 pattern=0000010000000000\\ | ||
+ | LED_MATRIX_PATTERN n=2 pos= 9 pattern=0000011000000000\\ | ||
+ | LED_MATRIX_PATTERN n=2 pos=10 pattern=0000011000000000\\ | ||
+ | LED_MATRIX_PATTERN n=2 pos=11 pattern=0000011100000000\\ | ||
+ | LED_MATRIX_PATTERN n=2 pos=12 pattern=0000011110000000\\ | ||
+ | LED_MATRIX_PATTERN n=2 pos=13 pattern=0000011110000000\\ | ||
+ | LED_MATRIX_PATTERN n=2 pos=14 pattern=0000011111000000\\ | ||
+ | Im using my VLR-8oDisp board to show the Values of every item. You can change it to any other type of Display-setting... lcd_pos=6:1:5 {6=Display number : 1= X-axis : 5= Y-Axis (row)} |
