fadercore_-_vlr-8enc [2014/07/27 09:52] novski |
fadercore_-_vlr-8enc [2014/07/27 21:23] novski |
Line 1: | Line 1: | ||
- | ====== Fadercore ====== | + | [[fadercore_-_fadermodule_for_audio_daw|Fadercore]] |
Standard 220mm wide modules | Standard 220mm wide modules | ||
Line 161: | Line 161: | ||
LED_MATRIX_PATTERN n=2 pos=13 pattern=0000011110000000\\ | LED_MATRIX_PATTERN n=2 pos=13 pattern=0000011110000000\\ | ||
LED_MATRIX_PATTERN n=2 pos=14 pattern=0000011111000000\\ | LED_MATRIX_PATTERN n=2 pos=14 pattern=0000011111000000\\ | ||
+ | Im using my VLR-8oDisp board to show the Values of every item. You can change it to any other type of Display-setting... lcd_pos=6:1:5 {6=Display number : 1= X-axis : 5= Y-Axis (row)} |
