fadercore_-_vlr-8x16ledmeter [2014/07/28 16:37] novski |
fadercore_-_vlr-8x16ledmeter [2014/07/30 11:58] novski |
Line 7: | Line 7: | ||
A solution to add 8 Meters with 16 LEDs for each Meter. | A solution to add 8 Meters with 16 LEDs for each Meter. | ||
- | It contains 2 different Types of PCBs one is the LEDmatrix and the other a slim PCB to mount 16LEDs | + | It contains 2 different Types of PCBs one is the LEDmatrix and the other a slim PCB to mount 16LEDs called meterboard. |
{{:fadercore_vlr-meterboard_beispiel_1_kanal_bestueckt.png?600|}} | {{:fadercore_vlr-meterboard_beispiel_1_kanal_bestueckt.png?600|}} | ||
Line 13: | Line 13: | ||
Eagle Files: [[https://github.com/novski/Midibox/tree/master/VLR-8x16LEDmeter]] | Eagle Files: [[https://github.com/novski/Midibox/tree/master/VLR-8x16LEDmeter]] | ||
- | {{:fadercore_vlr-ledmatrix_unbestueckt_top.png?200|}} {{:fadercore_vlr-meterboard_bestueckt_sideview.png?200|}} | + | {{:fadercore_vlr-ledmatrix_unbestueckt_top.png?200|}} {{:fadercore_vlr-meterboard_bestueckt_sideview.png?200|}}\\ |
{{:fadercore_vlr-ledmatrix_dimensions.png?300|}} {{:fadercore_vlr-meterboard_dimensions.png?200|}} | {{:fadercore_vlr-ledmatrix_dimensions.png?300|}} {{:fadercore_vlr-meterboard_dimensions.png?200|}} | ||
Line 56: | Line 56: | ||
==== Test it in MIOS ==== | ==== Test it in MIOS ==== | ||
- | To make it work with MIOS .NGC File we need to know how the shift-registers are connected.\\ | + | I use a Encoder connected directly to a DIN to test. |
- | \\ | + | Assuming that the DOUT is the first device on the chain of J8/9 we need to configure it like this:\\ |
- | **Inputs:**\\ | + | |
- | 1# Switch Columns 1-8\\ | + | |
- | **Outputs:**\\ | + | |
- | 1# ROW Outputs 1-6\\ | + | |
- | 2# RED LEDs 1-8\\ | + | |
- | 3# GREEN LEDs 1-8\\ | + | |
- | 4# BLUE LEDs 1-8\\ | + | |
- | Assuming that the VLR-3x8But is the first device on the chain of J8/9 we need to configure it like this:\\ | + | |
RESET_HW\\ | RESET_HW\\ | ||
LCD "%C"\\ | LCD "%C"\\ | ||
LCD "@(1:1:1)OLED1"\\ | LCD "@(1:1:1)OLED1"\\ | ||
- | LCD "@(2:1:1)OLED2"\\ | ||
- | LCD "@(3:1:1)OLED3"\\ | ||
- | LCD "@(4:1:1)OLED4"\\ | ||
- | LCD "@(5:1:1)OLED5"\\ | ||
- | LCD "@(6:1:1)OLED6"\\ | ||
- | LCD "@(7:1:1)OLED7"\\ | ||
- | LCD "@(8:1:1)OLED8"\\ | ||
- | # In this demo we configure individual brightness levels for the LEDs from EVENT_BUTTON events\\ | ||
- | LCD "@(1:10:1)RGB Demo #2"\\ | ||
- | DIN_MATRIX n=1 rows=4 sr_dout_sel1=1 sr_din1=1 button_emu_id_offset=1001\\ | + | # Test D-OUT LEDmatrix board\\ |
- | DOUT_MATRIX n=1 rows=4 sr_dout_r1=2 sr_dout_g1=3 sr_dout_b1=4 led_emu_id_offset=1025\\ | + | |
- | # These button functions forward their value also to LEDs\\ | + | DOUT_MATRIX n=1 rows=8 inverted=1 sr_dout_sel1=1 sr_dout_r1=2 sr_dout_r2=3\\ |
- | # it's possible to set the rgb levels in the button event, it will be forwarded as well!\\ | + | |
- | EVENT_BUTTON id=1001 fwd_id=LED:1025 type=NoteOn key=36 chn=1 rgb=15:0:0 lcd_pos=1:1:2 label="^std_btn"\\ | + | # Matrix control by a Encoder connected to DIN\\ |
- | EVENT_BUTTON id=1002 fwd_id=LED:1026 type=NoteOn key=37 chn=1 rgb=15:0:0 lcd_pos=2:1:2 label="^std_btn"\\ | + | ENC n=1 sr=1 pins=0:1 type=detented2\\ |
- | EVENT_BUTTON id=1003 fwd_id=LED:1027 type=NoteOn key=38 chn=1 rgb=15:0:0 lcd_pos=3:1:2 label="^std_btn"\\ | + | |
- | EVENT_BUTTON id=1004 fwd_id=LED:1028 type=NoteOn key=39 chn=1 rgb=15:0:0 lcd_pos=4:1:2 label="^std_btn"\\ | + | |
- | EVENT_BUTTON id=1005 fwd_id=LED:1029 type=NoteOn key=40 chn=1 rgb=15:0:0 lcd_pos=5:1:2 label="^std_btn"\\ | + | |
- | EVENT_BUTTON id=1006 fwd_id=LED:1030 type=NoteOn key=41 chn=1 rgb=15:0:0 lcd_pos=6:1:2 label="^std_btn"\\ | + | |
- | EVENT_BUTTON id=1007 fwd_id=LED:1031 type=NoteOn key=42 chn=1 rgb=15:0:0 lcd_pos=7:1:2 label="^std_btn"\\ | + | |
- | EVENT_BUTTON id=1008 fwd_id=LED:1032 type=NoteOn key=43 chn=1 rgb=15:0:0 lcd_pos=8:1:2 label="^std_btn"\\ | + | |
- | EVENT_BUTTON id=1009 fwd_id=LED:1033 type=NoteOn key=52 chn=1 rgb=0:15:0 lcd_pos=1:1:3 label="^std_btn"\\ | + | EVENT_ENC id= 1 fwd_id=LED_MATRIX:1 type=CC chn= 1 cc= 24 lcd_pos=1:1:2 label="^std_enc" LED_MATRIX_PATTERN=1\\ |
- | EVENT_BUTTON id=1010 fwd_id=LED:1034 type=NoteOn key=53 chn=1 rgb=0:15:0 lcd_pos=2:1:3 label="^std_btn"\\ | + | |
- | EVENT_BUTTON id=1011 fwd_id=LED:1035 type=NoteOn key=54 chn=1 rgb=0:15:0 lcd_pos=3:1:3 label="^std_btn"\\ | + | |
- | EVENT_BUTTON id=1012 fwd_id=LED:1036 type=NoteOn key=55 chn=1 rgb=0:15:0 lcd_pos=4:1:3 label="^std_btn"\\ | + | |
- | EVENT_BUTTON id=1013 fwd_id=LED:1037 type=NoteOn key=56 chn=1 rgb=0:15:0 lcd_pos=5:1:3 label="^std_btn"\\ | + | |
- | EVENT_BUTTON id=1014 fwd_id=LED:1038 type=NoteOn key=57 chn=1 rgb=0:15:0 lcd_pos=6:1:3 label="^std_btn"\\ | + | |
- | EVENT_BUTTON id=1015 fwd_id=LED:1039 type=NoteOn key=58 chn=1 rgb=0:15:0 lcd_pos=7:1:3 label="^std_btn"\\ | + | |
- | EVENT_BUTTON id=1016 fwd_id=LED:1040 type=NoteOn key=59 chn=1 rgb=0:15:0 lcd_pos=8:1:3 label="^std_btn"\\ | + | |
- | EVENT_BUTTON id=1017 fwd_id=LED:1041 type=NoteOn key=68 chn=1 rgb=0:0:15 lcd_pos=1:1:4 label="^std_btn"\\ | + | LED_MATRIX_PATTERN n= 1 pos= 0 pattern=0000000000000000\\ |
- | EVENT_BUTTON id=1018 fwd_id=LED:1042 type=NoteOn key=69 chn=1 rgb=0:0:15 lcd_pos=2:1:4 label="^std_btn"\\ | + | LED_MATRIX_PATTERN n= 1 pos= 1 pattern=1000000000000000\\ |
- | EVENT_BUTTON id=1019 fwd_id=LED:1043 type=NoteOn key=70 chn=1 rgb=0:0:15 lcd_pos=3:1:4 label="^std_btn"\\ | + | LED_MATRIX_PATTERN n= 1 pos= 2 pattern=1100000000000000\\ |
- | EVENT_BUTTON id=1020 fwd_id=LED:1044 type=NoteOn key=71 chn=1 rgb=0:0:15 lcd_pos=4:1:4 label="^std_btn"\\ | + | LED_MATRIX_PATTERN n= 1 pos= 3 pattern=1110000000000000\\ |
- | EVENT_BUTTON id=1021 fwd_id=LED:1045 type=NoteOn key=72 chn=1 rgb=0:0:15 lcd_pos=5:1:4 label="^std_btn"\\ | + | LED_MATRIX_PATTERN n= 1 pos= 4 pattern=1111000000000000\\ |
- | EVENT_BUTTON id=1022 fwd_id=LED:1046 type=NoteOn key=73 chn=1 rgb=0:0:15 lcd_pos=6:1:4 label="^std_btn"\\ | + | LED_MATRIX_PATTERN n= 1 pos= 5 pattern=1111100000000000\\ |
- | EVENT_BUTTON id=1023 fwd_id=LED:1047 type=NoteOn key=74 chn=1 rgb=0:0:15 lcd_pos=7:1:4 label="^std_btn"\\ | + | LED_MATRIX_PATTERN n= 1 pos= 6 pattern=1111110000000000\\ |
- | EVENT_BUTTON id=1024 fwd_id=LED:1048 type=NoteOn key=75 chn=1 rgb=0:0:15 lcd_pos=8:1:4 label="^std_btn"\\ | + | LED_MATRIX_PATTERN n= 1 pos= 7 pattern=1111111000000000\\ |
+ | LED_MATRIX_PATTERN n= 1 pos= M pattern=1111111100000000\\ | ||
+ | LED_MATRIX_PATTERN n= 1 pos= 8 pattern=1111111110000000\\ | ||
+ | LED_MATRIX_PATTERN n= 1 pos= 9 pattern=1111111111000000\\ | ||
+ | LED_MATRIX_PATTERN n= 1 pos=10 pattern=1111111111100000\\ | ||
+ | LED_MATRIX_PATTERN n= 1 pos=11 pattern=1111111111110000\\ | ||
+ | LED_MATRIX_PATTERN n= 1 pos=12 pattern=1111111111111000\\ | ||
+ | LED_MATRIX_PATTERN n= 1 pos=13 pattern=1111111111111100\\ | ||
+ | LED_MATRIX_PATTERN n= 1 pos=14 pattern=1111111111111110\\ | ||
+ | LED_MATRIX_PATTERN n= 1 pos=15 pattern=1111111111111111\\ | ||
- | Im using my VLR-8oDisp board to show the Values of every item. You can change it to any other type of Display-setting... lcd_pos=6:1:5 {6=Display number : 1= X-axis : 5= Y-Axis (row)} | + | Im using my VLR-8oDisp board to show the Values of the encoder. You can change it to any other type of Display-setting... lcd_pos=6:1:5 {6=Display number : 1= X-axis : 5= Y-Axis (row)} |
For any Comment or Question: Forum Thread??? | For any Comment or Question: Forum Thread??? |
