This bulk order is officialy closed but I have bought some extra PCBs for latecomers. If you want ones, email me (jeromebo at free dot fr) the quantity you would like and your personal informations:
The price of each board is 9€ (I had to buy extra shipping material) and the Paypal fee on the total is 6.5% (with 5% I lost money).
Welcome to the wiki page of the bulk order of the control surface board featuring combo DINx4 and improved DOUTx4 modules with 16 LEDrings and 16 encoders.
You can find the tread of this bulk order here.
You can find the tread of the PCB design here.
This bulk order concern the last revision of the PCB that is rev 2.4.
The price is 14€ 11€ 9€ 8,50€ each PCB (+ shipping) - This price can be slightly less expensive regarding number of boards ordered -.
Top side: Encoders and LEDs.
The PCB is two sides white silkscreened on green FR4 material, 1.6mm thickness, 1Oz copper, HASL, 100% E-tested & ROHS compliant.
The board is 3,368 x 13,472 inch (342,2mm x 85,5mm): just less than 2U standard.
The diameter of each LEDring is 1,299 inch (33 mm) with the use of 3mm LED.
You will find the coordinates of LEDs/Encoders in this files (new version with better accuracy positioning!).
X | Y |
0,16 | 0,16 |
6,736 | 0,16 |
13,312 | 0,16 |
0,16 | 3,208 |
6,736 | 3,208 |
13,312 | 3,208 |
Quantity | Device | Parts | REICHELT | MOUSER | Note |
2 | ULN2803 Transistors Darlington arrays | ULN2803#1, ULN2803#2 | ULN 2803A | 595-ULN2803AN | optional |
8 | 10k 6 Pin SIL resistor network | RN3, RN4, RN5, RN6, RN7, RN8, RN9, RN10 | SIL 6-5 10K | 264-10K-RC | |
4 | 74HC165 | IC1, IC2, IC3, IC4 | 74HC 165 | 511-M74HC165 | |
4 | 74HC595 | SR1, SR2, SR3, SR4 | 74HC 595 | 511-M74HC595 | |
8 | Ceramic Cap 100nF=0,1uF “104” | C1, C2, C3, C4, C6, C7, C8, C9 | Z5U-2,5 100n | 80-C412C104K5R | |
1 | Polarized Electrolytic Capacitor 100 uF | C5 | rad 100/16 | 140-REA101M1CBK0611P | |
2 | 220 Ohm 16 Pin DIL resistor network | RN1, RN2 | - | 652-4116R-1LF-220 | or 16x Resistor 220 Ohm |
16 | 220 Ohm metal film resistor | 8 for RN1, 8 for RN2 | METALL 220 | MF1/4DCT52R2200F | Instead the 2 RNs above |
2 | 2-row DIL Header (2×5 pins) | “IN”, “OUT” | SL 2X10G 2,54 | 649-67996-420HLF | For Reichelt, buy only 1 item and cut it in 2 parts |
1 | 1-row SIL Header (1×16 pins) | “TO_SWITCH_BOARD” | SL 1X36G 2,54 | 649-68001-416HLF | optional |
16 | PEC16-4020F-N0024 | ENC1, ENC2, … , ENC16 | - | 652-PEC16-4020FN0024 | Undetended - without build-in switch |
or | PEC16-4020F-S0024 | - | 652-PEC16-4020FS0024 | Undetended - with build-in switch | |
10 | Socket 16 pins | - | GS 16 | 571-1-390261-4 | |
2 | Socket 18 pins | - | GS 18 | 571-1-390261-5 | 8 (NOT 9) bridges to solder if not using ULN2803s |
256 | LED 3mm or rectangular (2x5x7mm) | LED1, LED2, … ,LED256 | LED 3MM RT | - | Reichelt model recommended |
This is a Mouser Orderlist (Thank you Lamouette). You have only to add your LEDs and Pinheaders.
Since Tk discovered a brightness problem with some rectangular 5x2x7mm LEDs, we found it useful to create a list of LEDs wich are successfully or unsuccessfully tested. Members are welcome to edit this page to add their LED feedback.
Model | Type | Link | Good | Not good | Comment | Author |
Kingbright WP103HD | 5x2x7mm rectangular | Mouser | X | Tk | ||
LED 3MM RT | 3mm round | Reichelt | X | Tk | ||
“10001” | 5x2x7mm rectangular | auspiciousmall.com | X | Fairlightiii | ||
Kingbright L-934ID | 3mm round | Segor Electronics | X | rvlt |
Each LEDring is composed of 16 LEDs.
You can use 3mm LEDs or 5x2x7mm rectangular LEDs (because the different angles of the LEDs in the LEDring) or all other LED with 0.1 inch (2,54 mm) leads spacing.
You can use instead PEC16-4xxxF-Sxxxx series (with built-in switch). Probably others built-in switch encoders comply the PCB footprint but you have to compare before datasheets.
If you use switched encoders, one of the two pins of the built-in switch is grounded while the other pin is connected to a pin of this SIL connector.
The silkscreen include the name of each switch.
Be careful to the connection to the MBHP_CORE_LPC17 module because it could be confusing, since the SO pin of J8/9 has to be connected to the SI pin of the LRE2x8 board, and SI to the SO pin (for MBHP_DOUT/DIN we usually have the same names for these signals, this detail has been overlooked).
You can use or not Transistors Darlington arrays.
In the second case (and only in this case), you need to bridge 16 of the 18 free pins 2 by 2 (in red on the picture):
An idea is to use e.g. DIP16 Switch. (NT 08 at Reichelt). |
As in the SmashTV's PCB, you can replace a DIL resistor network by 8 resistors.
In this case I recommend to use 1% metal film resistors because with the tolerance of standard carbon resistors you could see maybe different brightness of each LED of the LEDring.
Be careful when sourcing SIL resistor networks because a 6 Pin SIL resistor network can be 5 commoned resistors (what you need here) or 3 independant resistors.
You can download a better definition version here. |
You can chain 4 of this board or connect yours extra DIN/DOUT modules e.g. on the DIL connector named “OUT”.
You can connect also this board at the end of the chain and connect this board with the “IN” connector after yours others modules.
With the use of the upcoming MIDIbox NG (planned for Winter 2012/13) you will be able to have 2 chains of 4 boards each (2x4x16=128 encoders and 2x4x16=128 LEDrings).
I won't refund in case of the shipment get lost.
COUNTRY | Insurance level | Number of PCB | |||||||
1 | 2 | 3 | 4 | 5 | 6 | 7 | 8 | ||
France | Without insurance | 1,80 € | 3,10 € | 3,10 € | 3,10 € | 4,00 € | 4,00 € | 4,00 € | 4,00 € |
France | With insurance 16€ | 6,18 € | 7,03 € | ||||||
France | With insurance 153€ | 7,63 € | 7,63 € | 7,63 € | 8,58 € | 8,58 € | 8,58 € | 8,58 € | |
European Union (UK, Germany, Greece, …) & Swiss | Without insurance | 4,10 € | 6,10 € | 6,10 € | 6,10 € | 8,75 € | 8,75 € | 8,75 € | 8,75 € |
European Union (UK, Germany, Greece, …) & Swiss | With insurance 45€ | 9,70 € | 11,70 € | 11,70 € | 11,70 € | 14,35 € | 14,35 € | 14,35 € | 14,35 € |
European Union (UK, Germany, Greece, …) & Swiss | With insurance 150€ | 15,35 € | 15,35 € | 15,35 € | |||||
Norway | Without insurance | 5,60 € | 7,35 € | 7,35 € | 7,35 € | 10,80 € | 10,80 € | 10,80 € | 10,80 € |
Norway | With insurance 45€ | 11,20 € | 12,95 € | 12,95 € | 12,95 € | 16,40 € | 16,40 € | 16,40 € | 16,40 € |
Norway | With insurance 150€ | 17,40 € | 17,40 € | 17,40 € | |||||
US, Canada, Brazil, Australia, … | Without insurance | 5,60 € | 7,35 € | 7,35 € | 7,35 € | 10,80 € | 10,80 € | 10,80 € | 10,80 € |
US, Canada, Brazil, Australia, … | With insurance 45€ | 11,20 € | 12,95 € | 12,95 € | 12,95 € | 16,40 € | 16,40 € | 16,40 € | 16,40 € |
US, Canada, Brazil, Australia, … | With insurance 150€ | 17,40 € | 17,40 € | 17,40 € |
If you take “with insurance” you will be compensated of the amount of the insurance in case of lost of the parcel and your shipment is tracked (until your door in this country: Germany, Belgium, Denmark, Finland, UK, Hong-Kong, Ireland, Japan, Luxembourg, The Netherlands, Slovakia, Sweden, Swiss and until the French frontier for the others country). In any case I receive a proof of delivery.
For (french language) tracking page, it's here. Fill the textbox “Numéro de suivi” with your number.
If you take “without insurance” there's no tracking of the parcel.
If your country is not in this table, or if you want more PCBs, PM or email me.
Because there are not enough stocked DIL resistor networks in Mouser shop, this is the new time-frame:
By putting your name on the list you agree to the terms and conditions described here: www.midibox.org/dokuwiki/nils_bulk_terms.
Use your full and correct FORUM (not the wiki) name, so I can reach you via PM or email.
Click on the “Edit this page” button (top left corner) and add your MIDIbox username and the number of components you would like.
UPDATE THE QUANTITIES TO THE END OF THE LIST.
Do not edit anything else on this page (except to correct my English or spelling mistakes!).
Username | PCB | 10k SIL RN | 220 Ohm DIL RN |
8,50€ (November 20th) | 0,08€ (November 20th) | 0,26€ (November 16th) | |
Fairlightiii | 20 | 24 | 12 |
jojjelito | 8 | 64 | 16 |
NorthernLightX | 1 | ||
rvlt | 4 | 32 | 8 |
Hawkeye | 8 | 64 | 16 |
Lamouette | 4 | 32 | 8 |
Antix | 2 | 40 | |
shimoda | 3 | 24 | 6 |
monokinetic | 2 | ||
norbim1 | 2 | 16 | 4 |
benuron | 2 | 16 | 4 |
defenestration | 4 | 32 | 8 |
kelargo | 4 | 32 | 8 |
TK | 4 | 32 | 8 |
johnniebee | 4 | 32 | 8 |
borbathegeek | 2 | 16 | 4 |
Beat | 4 | 32 | 8 |
gslug | 4 | 32 | 8 |
grizz | 4 | 32 | 8 |
latigid on | 2 | 16 | 4 |
zephyrin | 2 | ||
gtxdude | 2 | ||
Prosperity | 2 | 16 | 4 |
dnode | 6 | 48 | 12 |
ilmenator | 4 | ||
toadstool | 2 | 16 | 4 |
mburch | 2 | 16 | 4 |
lylehaze | 2 | 16 | 4 |
V`cent | 3 | 24 | 6 |
TheProf | 2 | ||
anderspe | 2 | 16 | 4 |
taximan | 8 | 64 | 16 |
ermangaver | 2 | 16 | 4 |
Elektruck | 8 | 70 | 20 |
MaG2k | 4 | 32 | 10 |
dsdonnes | 2 | 16 | 4 |
shaduz | 2 | 16 | 4 |
103 Bert | 1 | 8 | 2 |
dinama | 4 | 32 | 8 |
ctrl+z | 1 | 8 | 2 |
gomiboy99 | 4 | ||
raoulblues | 4 | 32 | 10 |
boops | 4 | 32 | 10 |
rosch | 2 | 4 | |
Dreadknot | 1 | 10 | 8 |
Milky | 4 | 32 | 10 |
HerrPaule | 2 | 10 | 6 |
sam | 4 | 36 | 10 |
fantomxr | 2 | 20 | 6 |
technobreath | 1 | 8 | 2 |
Mirmidi | 4 | 32 | 8 |
Total : | 181 | 1194 | 320 |
As many people want some onboard components and as resistor networks (SIL and DIL) are not easy to find at good price for few quantity, I add a bulk order only for SIL and DIL resistor networks to this bulk order. Others components (except encoders) are easily “sourcable” on Internet.
I have modified the list with 2 new columns.
Importants informations:
Jérôme aka Fairlightiii.
—–I tried to be clear but if I made a mistake or if I forgot something, don't hesitate to say it in the forum.—–
