fantomxr [2015/01/21 12:23] fantomxr |
fantomxr [2015/01/21 12:37] fantomxr |
Line 3: | Line 3: | ||
On this page I will list pcb designs I made. Some are tested, some are not. I will add a note to every PCB. | On this page I will list pcb designs I made. Some are tested, some are not. I will add a note to every PCB. | ||
+ | Most of them are not that special. But they make the midibox-life easier. | ||
- | ==== Fatar keybed adapter ==== | ||
- | This is a adapter which is made for connect a FATAR keybed directly to the DIO-matrix without soldering. The rest should be self explaining. | ||
- | Status: **tested**\\ | ||
- | Eagle *.brd: [[https://www.dropbox.com/s/y5kh9n5zghuzk0v/88_Fatar%20Adapter.brd?dl=0|Fatar adapter]] | ||
- | {{:fatar_adapter.png?500|}} | ||
==== LED Ring ==== | ==== LED Ring ==== | ||
Line 34: | Line 25: | ||
Status: **tested**\\ | Status: **tested**\\ | ||
- | Eagle *.brd: [[https://www.dropbox.com/s/zgblcichkkk936a/LED bar_SMD.brd?dl=0|LED Bar]] | + | Eagle *.brd: [[https://www.dropbox.com/s/zgblcichkkk936a/LED bar_SMD.brd?dl=0|Download]] |
{{:fantomxr_led_bar.png?200|}} | {{:fantomxr_led_bar.png?200|}} | ||
Line 48: | Line 39: | ||
Status: **untested**\\ | Status: **untested**\\ | ||
- | Eagle *.brd: [[https://www.dropbox.com/s/zgblcichkkk936a/4x_Switchboard_M.brd?dl=0|4x Switchboard]] | + | Eagle *.brd: [[https://www.dropbox.com/s/zgblcichkkk936a/4x_Switchboard_M.brd?dl=0|Download]] |
{{:fantomxr_4xswitch.png?500|}} | {{:fantomxr_4xswitch.png?500|}} | ||
Line 60: | Line 51: | ||
- | Eagle *.brd: [[https://www.dropbox.com/s/22pcihmt7j4r4wa/8x_Switchboard_M.brd?dl=0|8x Switchboard]] | + | Eagle *.brd: [[https://www.dropbox.com/s/22pcihmt7j4r4wa/8x_Switchboard_M.brd?dl=0|Download]] |
{{:fantomxr_8xswitch.png?500|}} | {{:fantomxr_8xswitch.png?500|}} | ||
+ | ==== Fatar keybed adapter ==== | ||
+ | This is a adapter which is made for connect a FATAR keybed directly to the DIO-matrix without soldering. The rest should be self explaining. | ||
+ | Status: **tested**\\ | ||
+ | Eagle *.brd: [[https://www.dropbox.com/s/y5kh9n5zghuzk0v/88_Fatar%20Adapter.brd?dl=0|Fatar adapter]] | ||
+ | {{:fatar_adapter.png?500|}} | ||
+ | ==== DIO Adapter 2x6pin ==== | ||
+ | This is a adapter which I made for an easier matrix connection in conjunction with my switchboards (see above). Just connect the 8pins of the top row of J3 on the DIO to the DIO Input on this board + one of the pins of the bottom row of J3 to the row-input. The forward-connector allows to chain these pcbs. | ||
+ | Status: **untested**\\ | ||
+ | Eagle *.brd: [[https://www.dropbox.com/s/evby49o42hru6yt/DIO-Adapter%208%20auf%202x6pin.brd?dl=0|Download]] | ||
+ | {{:fantomxr_dio_6pin.png?500|}} | ||
+ | ==== DIO Adapter 1x10pin ==== | ||
+ | Same as above but for 10pin. Can also be chained. | ||
+ | Eagle *.brd: [[https://www.dropbox.com/s/7flat7vsjr9vqbb/DIO-Adapter%208%20auf%201x10pin.brd?dl=0|Download]] | ||
+ | {{:fantomxr_dio_10pin.png?500|}} | ||
+ | ==== 10pin splitter ==== | ||
+ | This is an adapter for split an 10pin pinheader into 2x 6pin. This is useful, if you want to connect two of my 4x switchboards directly to a DIN module. | ||
+ | Eagle *.brd: [[https://www.dropbox.com/s/ru4wxj5p2mrh3mv/10%20auf%202x3.brd?dl=0|Download]] | ||
+ | {{:fantomxr_10pin_split.png?200|}} | ||
+ | ==== USB I/O ==== | ||
+ | Because the Neutrik USB jack which comes in a D-housing is quite expensive, I set up this little board. | ||
+ | Eagle *.brd: [[https://www.dropbox.com/s/8d4t99wnr1p62hb/USB-Platine.brd?dl=0|Download]] | ||
+ | {{:fantomxr_usb_platine.png?200|}} | ||
