fantomxr [2015/01/21 12:28] fantomxr |
fantomxr [2015/01/21 12:37] fantomxr |
Line 3: | Line 3: | ||
On this page I will list pcb designs I made. Some are tested, some are not. I will add a note to every PCB. | On this page I will list pcb designs I made. Some are tested, some are not. I will add a note to every PCB. | ||
+ | Most of them are not that special. But they make the midibox-life easier. | ||
Line 54: | Line 55: | ||
{{:fantomxr_8xswitch.png?500|}} | {{:fantomxr_8xswitch.png?500|}} | ||
==== Fatar keybed adapter ==== | ==== Fatar keybed adapter ==== | ||
Line 70: | Line 73: | ||
Status: **untested**\\ | Status: **untested**\\ | ||
- | Eagle *.brd: [[https://www.dropbox.com/s/y5kh9n5zghuzk0v/DIO-Adapter 8 auf 2x6pin.brd?dl=0|Download]] | + | Eagle *.brd: [[https://www.dropbox.com/s/evby49o42hru6yt/DIO-Adapter%208%20auf%202x6pin.brd?dl=0|Download]] |
{{:fantomxr_dio_6pin.png?500|}} | {{:fantomxr_dio_6pin.png?500|}} | ||
Line 77: | Line 80: | ||
+ | ==== DIO Adapter 1x10pin ==== | ||
+ | Same as above but for 10pin. Can also be chained. | ||
+ | Status: **untested**\\ | ||
+ | Eagle *.brd: [[https://www.dropbox.com/s/7flat7vsjr9vqbb/DIO-Adapter%208%20auf%201x10pin.brd?dl=0|Download]] | ||
+ | {{:fantomxr_dio_10pin.png?500|}} | ||
+ | ==== 10pin splitter ==== | ||
+ | This is an adapter for split an 10pin pinheader into 2x 6pin. This is useful, if you want to connect two of my 4x switchboards directly to a DIN module. | ||
+ | Eagle *.brd: [[https://www.dropbox.com/s/ru4wxj5p2mrh3mv/10%20auf%202x3.brd?dl=0|Download]] | ||
+ | {{:fantomxr_10pin_split.png?200|}} | ||
+ | ==== USB I/O ==== | ||
+ | Because the Neutrik USB jack which comes in a D-housing is quite expensive, I set up this little board. | ||
+ | Status: **tested**\\ | ||
+ | Eagle *.brd: [[https://www.dropbox.com/s/8d4t99wnr1p62hb/USB-Platine.brd?dl=0|Download]] | ||
+ | {{:fantomxr_usb_platine.png?200|}} | ||
