Both sides previous revision Previous revision | Last revision Both sides next revision | ||
fantomxr [2015/01/21 12:33] fantomxr |
fantomxr [2015/01/21 12:36] fantomxr |
Line 3: | Line 3: | ||
On this page I will list pcb designs I made. Some are tested, some are not. I will add a note to every PCB. | On this page I will list pcb designs I made. Some are tested, some are not. I will add a note to every PCB. | ||
+ | Most of them are not that special. But they make the midibox-life easier. | ||
Line 97: | Line 98: | ||
{{:fantomxr_10pin_split.png?200|}} | {{:fantomxr_10pin_split.png?200|}} | ||
+ | ==== USB I/O ==== | ||
+ | Because the Neutrik USB jack which comes in a D-housing is quite expensive, I set up this little board. | ||
+ | Status: **tested**\\ | ||
+ | Eagle *.brd: [[https://www.dropbox.com/s/8d4t99wnr1p62hb/USB-Platine.brd?dl=0|Download]] | ||
+ | {{:ffantomxr_usb_platine.png?200|}} | ||
