findbuddha [2011/11/05 04:05] findbuddha removed SEQ error (solved) |
findbuddha [2012/02/03 07:58] findbuddha Added some issues |
Line 28: | Line 28: | ||
KNOWN ISSUES / BUILD SUGGESTIONS: | KNOWN ISSUES / BUILD SUGGESTIONS: | ||
+ | - 2x5 connectors in seq PCB were not flipped to take into account being on the bottom of the board. This is correctable by swapping the wires as needed in the ribbon cable from the DIN/DOUT PCBs.\\ | ||
- 5x17.brd contains an error due to a problem in TK's original BLM schematic. I'll be working on a software fix for this, it should be simple.\\ | - 5x17.brd contains an error due to a problem in TK's original BLM schematic. I'll be working on a software fix for this, it should be simple.\\ | ||
- blm-full.* are currently untested, except as used in the 5x17.brd. The above schematic error is corrected.\\ | - blm-full.* are currently untested, except as used in the 5x17.brd. The above schematic error is corrected.\\ | ||
- | - blm-scalar.* contain an error. Pins I4-I7 are mirrored. This is easily fixed with a connector modification, and the blm-scalar module seems to work as intended.\\ | + | - blm-scalar.* contain an error. Pins I4-I7 are mirrored. This is easily fixed with a connector modification, and the blm-scalar module seems to work as intended. A corrected but currently untested file is separately available below.\\ |
- P3-frontpanel.svg has blue (cut) lines around engraving marks for some of the fader scale lines. I have worked around this by filling the holes with paint.\\ | - P3-frontpanel.svg has blue (cut) lines around engraving marks for some of the fader scale lines. I have worked around this by filling the holes with paint.\\ | ||
- Good idea to request ponoko to do the engraving on the matte side. My prototyping runs came with the engraving on the glossy side.\\ | - Good idea to request ponoko to do the engraving on the matte side. My prototyping runs came with the engraving on the glossy side.\\ | ||
Line 39: | Line 40: | ||
DESIGN FILES: | DESIGN FILES: | ||
- | {{:findbuddha:findbuddha-shared-wiki-docs-0.1.zip|}} | + | {{:findbuddha:findbuddha-shared-wiki-docs-0.1.zip|}}\\ |
+ | {{:findbuddha:blm-scalar-corrected.zip|}}\\ | ||
+ | {{:findbuddha:fb-kicad-library-21-09-2011.zip|}} |
