forum_highlights_huis [2010/10/05 02:43] googleberry |
forum_highlights_huis [2010/10/05 03:55] googleberry |
Line 1: | Line 1: | ||
- | ====== MIDIBOX HUIs ====== | + | |
===== MIDIBOX HUIs ===== | ===== MIDIBOX HUIs ===== | ||
- | * [[http://www.midibox.org/dokuwiki/doku.php?id=projects|MIDIBOX PROJECTS WIKI PAGE]] | + | Forum threads and questions about the MIDIbox HUI projects. More information can be found at the [[http://www.midibox.org/dokuwiki/doku.php?id=projects|MIDIBOX PROJECTS WIKI PAGE]] |
Line 36: | Line 37: | ||
* [[http://midibox.org/forums/topic/5555-chord-and-seqarpeggio-function-is-it-possible/|Chord & Sequencer Arpeggio function??]] | * [[http://midibox.org/forums/topic/5555-chord-and-seqarpeggio-function-is-it-possible/|Chord & Sequencer Arpeggio function??]] | ||
* [[http://midibox.org/forums/topic/5327-how-many-lcd-diplays-per-core/|How many LCD displays per CORE module??]] | * [[http://midibox.org/forums/topic/5327-how-many-lcd-diplays-per-core/|How many LCD displays per CORE module??]] | ||
+ | * [[http://midibox.org/forums/topic/13697-midibox-of-the-week-midibox-mmc-control-unit-of-ssp/|MIDIbox based MMC transport controller]] | ||
+ | * [[http://midibox.org/forums/topic/13591-meta-event-help|META-HANDLER help!! (SYSEX)]] | ||
Line 75: | Line 78: | ||
* [[http://midibox.org/forums/topic/5274-powering-mblc-extension/|MIDIbox LC Power Supply??]] | * [[http://midibox.org/forums/topic/5274-powering-mblc-extension/|MIDIbox LC Power Supply??]] | ||
* [[http://midibox.org/forums/topic/5663-is-making-a-midi-drum-pad-possible/|MIDIbox LC - Adding drum pads?]] | * [[http://midibox.org/forums/topic/5663-is-making-a-midi-drum-pad-possible/|MIDIbox LC - Adding drum pads?]] | ||
== User Projects == | == User Projects == |
