Show pagesource
forum_highlights_huis
MIDIBOX HUIs
MIDIbox 64/64e
MIDIbox LC
MIDIbox MM
MIDIBOX HUIs
MIDIBOX PROJECTS WIKI PAGE
MIDIbox 64/64e
The Making of a MIDIbox64
Where to Start??
Where to Start??
Adding MIDIbox64 LEDS?
Reducing the number of LED's in MIDIbox64 encoder LED rings
Sending different CC# based on encoder turn direction
MIDIbox64 with MAX-MSP??
Simple MIDIbox controller using just a core module??
Encoders outputting SYSEX Messages??
Sysex Messages
Safe wiring distance between CORE/DOUT/DIN/AOUT/AIN??
BANKING - Buttons/Encoders with more than one function??
BANKING - Button/Encoder layers??
Midi Latency?
META-EVENT for up/down octave switching??
USB to MIDI??
Rotary Encoder with Switch Query
Forwarding MIDI IN to MIDI OUT??
Additional MIDI IN Port??
Changing button assignments with the push of a button??
Motorfader only with the MIDIbox LC??
Button Behaviour?? (@OnOff/@OnOnly/@Toggle)
Velocity Sensitive Pads?
MIDIbox64 resolution??
MIDIbox for analogue console automation??
|MIDIbox64/64e - Pots or Encoders??
Chord & Sequencer Arpeggio function??
How many LCD displays per CORE module??
User Projects
Protosx's MIDIbox64e
questionable's MIDIbox64 Traktor Controller.
K-rAd's MIDIbox64 Controller.
Gioxannes's Midibox64 driven Synth & Sequencer.
Logo's MIDIbox64
LX's MIDIbox project
Foona's MIDIbox64
stevesavage's MIDIbox64
MIDIbox LC
MIDIbox LC Tutorial
Can't find Schematics??
Protools Compatibility??
MIDIbox LC, more than 8 faders??
Encoders instead of faders??
Using no motorfaders??
Motorfaders??
Which motorfaders??
MIDIbox LC LCD feedback problems
Editing button functions for LC??
Inverting DOUT pins? (Bi-Coloured LEDs)
Linking CORE modules?? (More than 8 channels for LC?)
Minimal LC setup (transport/zoom/jog)??
MIDIbox LC sending midi events??
Using non-motorized faders with the LC?
Double GLCD display MIDIbox LC??
Graphical Knobs on the LCD Screen??
What can the LCD's show??
Midi Merger for the LC when using it with a Keyboard??
Are the VU meter bar graphs useful??
Simple/Slimmed-down MIDIbox LC??
MIDIbox LC Power Supply??
MIDIbox LC - Adding drum pads?
User Projects
cinhcet's MIDIbox LC
Protosx's MIDIbox LC
ssp's MIDIbox LC
Lorcan's MIDIbox LC (Work In Progress)
Axel's 24 channel MIDIbox LC
MIDIbox MM
Original MotorMix Inception
Converting an MIDIbox LC to a MIDIbox MotorMix
New application which supports Mackie HUI protocol
Master fader on motormix emulation??
Controller for Protools??
forum_highlights_huis.1286246568.txt.gz
· Last modified: 2010/10/05 02:42 by
googleberry
Show pagesource
Export to PDF
Rename Page
Back to top
