====== Building the GM5x5x5 ====== ==== Introduction ==== The GM5x5x5 is a midi interface for your computer. bla bla bla ==== Building Level ==== Noob guides have an difficulty indication from 1 to 5 where 1 is easy and 5 is hard to build. If you have never started a project before we urge you to start with a level 1 project first. We indicate this project as Building level 3 ===== Tools Needed ===== To start building your GM 5x5x5 board you will need some tools. Offcourse you could be creative and use whatever you like but this document is trying to be failsafe. * Soldering Iron * Soldering Flux * Wire Cutter * Beer * etc put in pictures and so ===== Component List ===== The list is build up from components that should be solderd on the board in this order. However exeptions can be made. See building chapter for changes. ==== Diodes ==== ==== Resistors ==== ==== Sockets ==== ==== Capacitors ==== ==== Other ==== ====== Building ====== ===== The Chip ===== {{:gm5x5x5:1.jpg|}} This is the most difficult part of the whole project. If you manage to pull it off the rest of the project will be a breeze. {{:gm5x5x5:2.jpg|}} {{:gm5x5x5:3.jpg|}} {{:gm5x5x5:4.jpg|}} {{:gm5x5x5:5.jpg|}} {{:gm5x5x5:6.jpg|}} {{:gm5x5x5:7.jpg|}} {{:gm5x5x5:8.jpg|}} {{:gm5x5x5:9.jpg|}} {{:gm5x5x5:a1.jpg|}} {{:gm5x5x5:a2.jpg|}} {{:gm5x5x5:a3.jpg|}} {{:gm5x5x5:a4.jpg|}} {{:gm5x5x5:a5.jpg|}} {{:gm5x5x5:a6.jpg|}} {{:gm5x5x5:a8.jpg|}} {{:gm5x5x5:a7.jpg|}}
