hardsid.dll [2011/01/19 22:57] flem |
hardsid.dll [2011/04/02 19:58] smithy |
Line 21: | Line 21: | ||
* A fast MIDI interface. [[http://www.ucapps.de/mbhp_usb_gm5.html|GM5]]-based interfaces has proven to be excellent for this use, but other interfaces can be used also | * A fast MIDI interface. [[http://www.ucapps.de/mbhp_usb_gm5.html|GM5]]-based interfaces has proven to be excellent for this use, but other interfaces can be used also | ||
* The hardsid.dll file | * The hardsid.dll file | ||
- | * Some software that supports use of the hardsid.dll | ||
* Some C64 software, games or SID-files | * Some C64 software, games or SID-files | ||
+ | * Some software that supports use of the hardsid.dll | ||
The MBSIDV2 can be of any model or build; SammichSID, MB6582, even a self-built modular version will work. The important issue is that it uses the MBSIDV2 firmware, which includes the SID-player routines. This means that MBSIDV1 firmware will not work since it does not include the needed SID-playing abilities. [[http://www.ucapps.de/midibox_sid_manual_up.html|look here]] for details on how to upgrade your MBSIDV1 to MBSIDV2. | The MBSIDV2 can be of any model or build; SammichSID, MB6582, even a self-built modular version will work. The important issue is that it uses the MBSIDV2 firmware, which includes the SID-player routines. This means that MBSIDV1 firmware will not work since it does not include the needed SID-playing abilities. [[http://www.ucapps.de/midibox_sid_manual_up.html|look here]] for details on how to upgrade your MBSIDV1 to MBSIDV2. | ||
Line 29: | Line 29: | ||
The hardsid.dll is managed, updated and provided by nILS. [[http://www.schickt.de/temp/hardsid.dll|Download it here!]] | The hardsid.dll is managed, updated and provided by nILS. [[http://www.schickt.de/temp/hardsid.dll|Download it here!]] | ||
+ | You can find C64 games and apps at [[http://www.c64.com/|c64.com]] and [[ftp://arnold.c64.org/pub/|Arnold FTP]]. You can find thousands of SID-files at [[http://www.6581-8580.com/|SOASC]] and [[http://www.hvsc.de/|hvsc.de]]. There are also a lot of C64 scene-websites that has a lot of nice demos, both classics and all new productions. | ||
+ | ====== HardSID compatible software ====== | ||
+ | [[http://www.gsldata.se/c64/spw/|Sidplay2]]([[http://www.gsldata.se/c64/spw/sidplayw.html|Old Sidplay]]) - A windows based Commodore 64 / SID File Music Player, which supports the ReSID emulation and HardSID device. | ||
+ | ***Note:** The older version has an audio mixer which allows you to mute individual channels. | ||
+ | [[http://www.sidmusic.org/sidplay/mac/|Sidplay for Mac]] - The Mac version of Sidplay is considered to be the best version out there. | ||
+ | [[http://www.viceteam.org/|Vice Emulator]] - One of the best, if not the best Commodore 64 emulators out there. | ||
+ | [[http://sourceforge.net/projects/goattracker2|GoatseTracker 2 (Win)]] - A crossplatform music editor for creating Commodore 64 music. | ||
+ | [[http://www.sidmusic.org/goattracker/mac/|GoatseTracker 2 (Mac)]] - Same as above, but written especially for MacOSX | ||
+ | **flemislazyflemislazyflemislazyflemislazyflemislazyflemislazyflemislazyflemislazyflemislazyflemislazyflemislazy | ||
+ | flemislazyflemislazyflemislazyflemislazyflemislazyflemislazyflemislazyflemislazyflemislazyflemislazyflemislazy | ||
+ | flemislazyflemislazyflemislazyflemislazyflemislazyflemislazyflemislazy** | ||
+ | ====== How to set up everything ====== | ||
+ | ====== Full list of links ====== |
