hd44780_compatible
MIOS supports internally Hitachi HD44780 compatible character displays
It's 'so called' industry standard for the character displays, but not all “standard” displays have this particular chip.
HD44780 compatible LCD controllers:
Controller: Manufacturer:
HD44780 Hitachi
KS0066 Samsung
KS0076 Samsung
KS0070 Samsung
S6A0069 Samsung
LC7985NA Sanyo
SED1278 Epson
NT3881D Novatek
SPLC780 Sunplus
MSM6222 OKI
NJU6408B NJR
NJU6468 NJR
NJU6470 NJR
Probably:
UM3881B 1) UMC
T7934 2) Toshiba
If your LCD has one of these chips, there are good changes to get it work. These chips have similar instruction set, data bus and timings are like original HD44780 (or faster, which shouldn't matter)
BUT this only means that controller chip is compatible with driver designed to HD44780
It's simply easier to get a display, that has datasheet available.
Common problems, if it isn't your soldering:
* First: There is no common standard for the display connector - You should get your LCDs datasheet to see the correct pinout.
* Second: Your display may need negative contrast voltage. 3)
* Third: Backlight not working? Maybe it's Electroluminescent (EL) type. 4)
And it's also good to know at least HD44780 displays can be initially programmed to different character sets - maybe your dirt cheap surplus display just talks greek to you :-D
More: MBHP LCD module page at uCApps.de
1)
I haven't found any reports about this chip
2)
instruction set compatible, has extra characters in CG ROM, it shouldn't matter
3)
Watch out for Vee pin. (Usually found in 'extended temperature range' displays)
4)
might need 'so called' inverter circuit to drive backlight
hd44780_compatible.1143309775.txt.gz · Last modified: 2006/10/15 09:35 (external edit)
