Next revision | Previous revision Last revision Both sides next revision | ||
home:project:midi_router [2008/12/09 09:45] martinsomerville created |
home:project:midi_router [2011/07/22 09:58] pabloharris |
Line 1: | Line 1: | ||
+ | ====== MIDI Router ====== | ||
- | ===MIDI ROUTER=== | ||
- | [[http://www.ucapps.de/midi_router.html|Midi Router on ucapps]] | + | ====== Intro ====== |
- | Type midirouter or midi router or midiro* (for mis-spellings) [[http://www.midibox.org/forum/index.php?action=search;advanced;search=|here]] to search forum. \\ | + | [[http://www.ucapps.de/midi_router.html|Midi Router]] is a project which allows you to route MIDI messages to/from multiple MIDI ports on the MIDIbox |
- | **Add links to photos!** | + | Please, if you decide to build a midirouter, take some photos before and after you put it in a case. Add them to a new forum topic and link((It's easy to insert a link, first sign in, click on the 'edit this page' button, then type 2 square open brackets, paste your url, and type 2 square closed brackets.)) it from here. Add any other info like what version of board was used and midirouter version etc...it helps newbies a lot. |
- | * Please, if you decide to build a midirouter, take some photos before and after you put it in a case. Add them to a new forum topic and link((It's easy to insert a link, first sign in, click on the 'edit this page' button, then type 2 square open brackets, paste your url, and type 2 square closed brackets.)) it from here. Add any other info like what version of board was used and midirouter version etc...it helps newbies a lot. | + | Also, if you are reading this and have built a midirouter that you created, it'd be cool if you take a photo too and insert a link to it from here. |
- | * Also, if you are reading this and have built a midirouter that you created, it'd be cool if you take a photo too and insert a link to it from here. | + | ====== Features ====== |
+ | Up to 8 MIDI I/Os | ||
+ | Customisable routing through simple C code | ||
+ | ====== Skills / Equipment Required ====== | ||
+ | [[:home:skills:tools|Tools]] | ||
+ | [[:home:skills:Soldering]] | ||
+ | ====== Hardware ====== | ||
+ | ===== What modules do I need? ===== | ||
+ | Adjust List as required: | ||
+ | [[:home:mbhp:module:core | Core Module]] | ||
+ | [[:home:mbhp:module:lcd | LCD Module]] | ||
+ | [[:home:mbhp:module:bankstick | Bankstick Module]] | ||
+ | [[:home:mbhp:module:din | DIN Module]] | ||
+ | [[:home:mbhp:module:dout | DOUT Module]] | ||
+ | [[:home:mbhp:module:iic_midi | IIC Midi Module]] | ||
+ | ===== Parts List ===== | ||
+ | List of pots, buttons, faders and blah - suggestions on good parts and where to buy them + how to hook them up - links | ||
+ | [[:home:mbhp:parts | Where to buy Parts]] | ||
+ | ===== Connections ===== | ||
+ | Connection diagrams - links if needed (create in you projects namespace | ||
+ | ===== Enclosure / Case ===== | ||
+ | Enclosure ideas - link to case construction tips? / provide space to encourage other users to wikify their case designs | ||
+ | ==== Enclosure References ==== | ||
+ | [[:home:skills:constructing_enclosures | Constructing Enclosures]] | ||
+ | ====== Software ====== | ||
+ | ===== Setting Up ===== | ||
+ | We recommend you read [[:home:software]] before you continue. | ||
+ | ===== Download ===== | ||
+ | Links | ||
+ | ===== Setup Instructions ===== | ||
+ | Up to you | ||
+ | ====== Extra ====== | ||
+ | [[:home:project:<thisproject>:manual | Usage Manual]] | ||
+ | Anything else | ||
+ | [[http://essaywritingservices.org/index.php|essay writing service]] | ||
