Midi Router is a project which allows you to route MIDI messages to/from multiple MIDI ports on the MIDIbox
Please, if you decide to build a midirouter, take some photos before and after you put it in a case. Add them to a new forum topic and link1) it from here. Add any other info like what version of board was used and midirouter version etc…it helps newbies a lot.
Also, if you are reading this and have built a midirouter that you created, it'd be cool if you take a photo too and insert a link to it from here.
Up to 8 MIDI I/Os
Customisable routing through simple C code
Adjust List as required:
List of pots, buttons, faders and blah - suggestions on good parts and where to buy them + how to hook them up - links
Connection diagrams - links if needed (create in you projects namespace
Enclosure ideas - link to case construction tips? / provide space to encourage other users to wikify their case designs
We recommend you read software before you continue.
Links
Up to you
