Next revision | Previous revision | ||
home:project:midibox_fm [2008/12/02 10:26] Durisian created |
home:project:midibox_fm [2016/06/27 12:55] psykhaze |
Line 1: | Line 1: | ||
- | [[http://www.ucapps.de/midibox_fm.html|MIDIBox FM Synthesiser]] is a project that uses [[:Soundcards with YMF262 and/or YAC512 chips|OPL3 FM soundchip]] (found from many old soundcards) controlled by midibox as a standalone synthesizer. | + | ====== MIDIbox FM ====== |
- | * [[:home:mbhp:module:opl3|OPL3 Module]] | + | //FIXME Update Things// |
- | * [[http://www.ucapps.de/midibox_fm.html|Overview]] <sup>uCApps</sup> | + | ====== Intro ====== |
- | * [[http://www.ucapps.de/midibox_fm_manual.html|User Manual]] <sup>uCApps</sup> | + | |
- | * [[:Soundcards with YMF262 and/or YAC512 chips]] | + | |
- | ---- | + | [[http://www.ucapps.de/midibox_fm.html|MIDIBox FM Synthesiser]] is a project that uses OPL3 FM soundchips (found from many old soundcards) controlled by MIDIBox as a standalone synthesizer. |
- | Other Links(Outside of MIDIBox): | + | ====== Features ====== |
- | * [[http://www.yamahasynth.com/download/sw1000xg/FMINFO.pdf|Yamaha's Definition of FM Synthesis and How it Works]] | + | |
+ | List 'em | ||
+ | ====== Skills / Equipment Required ====== | ||
+ | [[:home:skills:tools|Tools]] | ||
+ | [[:home:skills:Soldering]] | ||
+ | ====== Hardware ====== | ||
+ | ===== What modules do I need? ===== | ||
+ | Adjust List as required: | ||
+ | [[:home:mbhp:module:core | Core Module]] | ||
+ | [[:home:mbhp:module:opl3 | OPL3 Module]] | ||
+ | [[:home:mbhp:module:lcd | LCD Module]] | ||
+ | [[:home:mbhp:module:bankstick | Bankstick Module]] | ||
+ | [[:home:mbhp:module:din | DIN Module]] | ||
+ | [[:home:mbhp:module:dout | DOUT Module]] | ||
+ | [[:home:mbhp:module:aout | AOUT Module]] | ||
+ | ---or--- | ||
+ | [[:home:mbhp:module:aout_ng | AOUT_NG Module]] | ||
+ | ===== Parts List ===== | ||
+ | List of pots, buttons, faders and blah - suggestions on good parts and where to buy them + how to hook them up - links | ||
+ | [[:home:mbhp:parts | Where to buy Parts]] | ||
+ | ===== Soundcards ===== | ||
+ | A list of soundcards with YMF262 and/or YAC512 chips | ||
+ | [[:soundcards_with_ymf262_and_or_yac512_chips | Soundcards]] | ||
+ | ===== Connections ===== | ||
+ | Connection diagrams | ||
+ | == Control Cable Timing Issue == | ||
+ | It was been noted on [[http://www.midibox.org/forum/index.php/topic,13272.msg114171.html#msg114171|this forum article]] that errors can surface if the control cable between CORE and OPL3 boards is too long. | ||
+ | * The error shown in the forum article was found when running the testtone application. | ||
+ | * The specific error in the forum article that tone can be heard on outputs 1&2, but not outputs 3&4, however there is no guarantee that this is the only such error that could arise from long cable. | ||
+ | * The error was solved by shortening the control cable between CORE and OPLE3 boards. The cause was confirmed by switching back to a longer cable, at which point the error re-surfaced. | ||
+ | * The error was shown to be on the control cable (RS/A0/A1/WR), not the data cable (D0-D7), however it is advisable to make both these cables as short as is practicable. | ||
+ | ===== Enclosure / Case ===== | ||
+ | Enclosure ideas - link to case construction tips? / provide space to encourage other users to wikify their case designs | ||
+ | ==== Enclosure References ==== | ||
+ | [[:home:skills:constructing_enclosures | Constructing Enclosures]] | ||
+ | ====== Software ====== | ||
+ | ===== Setting Up ===== | ||
+ | We recommend you read [[:home:software]] before you continue. | ||
+ | ===== Download ===== | ||
+ | Links | ||
+ | ===== Setup Instructions ===== | ||
+ | Up to you | ||
+ | ====== Extra ====== | ||
+ | [[:home:project:midibox_fm:manual | Usage Manual]] | ||
+ | [[http://www.yamahasynth.com/download/sw1000xg/FMINFO.pdf|Yamaha's Definition of FM Synthesis and How it Works]] | ||
+ | [[http://www.ucapps.de/midibox_fm.html|Overview]] <sup>uCApps</sup> | ||
+ | [[http://www.ucapps.de/midibox_fm_manual.html|User Manual]] <sup>uCApps</sup> |
