home:project:midibox_fm [2008/12/20 03:40] stryd_one |
home:project:midibox_fm [2016/06/27 12:55] psykhaze |
Line 1: | Line 1: | ||
====== MIDIbox FM ====== | ====== MIDIbox FM ====== | ||
+ | //FIXME Update Things// | ||
====== Intro ====== | ====== Intro ====== | ||
Line 26: | Line 26: | ||
[[:home:mbhp:module:core | Core Module]] | [[:home:mbhp:module:core | Core Module]] | ||
+ | [[:home:mbhp:module:opl3 | OPL3 Module]] | ||
[[:home:mbhp:module:lcd | LCD Module]] | [[:home:mbhp:module:lcd | LCD Module]] | ||
Line 35: | Line 37: | ||
[[:home:mbhp:module:dout | DOUT Module]] | [[:home:mbhp:module:dout | DOUT Module]] | ||
- | [[:home:mbhp:module:aout_lc | AOUT_LC Module]] | + | [[:home:mbhp:module:aout | AOUT Module]] |
- | + | ---or--- | |
- | [[:home:mbhp:module:opl3 | OPL3 Module]] | + | [[:home:mbhp:module:aout_ng | AOUT_NG Module]] |
===== Parts List ===== | ===== Parts List ===== | ||
Line 45: | Line 46: | ||
[[:home:mbhp:parts | Where to buy Parts]] | [[:home:mbhp:parts | Where to buy Parts]] | ||
+ | ===== Soundcards ===== | ||
+ | A list of soundcards with YMF262 and/or YAC512 chips | ||
+ | [[:soundcards_with_ymf262_and_or_yac512_chips | Soundcards]] | ||
===== Connections ===== | ===== Connections ===== | ||
Connection diagrams | Connection diagrams | ||
+ | == Control Cable Timing Issue == | ||
+ | It was been noted on [[http://www.midibox.org/forum/index.php/topic,13272.msg114171.html#msg114171|this forum article]] that errors can surface if the control cable between CORE and OPL3 boards is too long. | ||
+ | * The error shown in the forum article was found when running the testtone application. | ||
+ | * The specific error in the forum article that tone can be heard on outputs 1&2, but not outputs 3&4, however there is no guarantee that this is the only such error that could arise from long cable. | ||
+ | * The error was solved by shortening the control cable between CORE and OPLE3 boards. The cause was confirmed by switching back to a longer cable, at which point the error re-surfaced. | ||
+ | * The error was shown to be on the control cable (RS/A0/A1/WR), not the data cable (D0-D7), however it is advisable to make both these cables as short as is practicable. | ||
===== Enclosure / Case ===== | ===== Enclosure / Case ===== | ||
Enclosure ideas - link to case construction tips? / provide space to encourage other users to wikify their case designs | Enclosure ideas - link to case construction tips? / provide space to encourage other users to wikify their case designs |
