home:project:midimon [2008/12/09 09:24] martinsomerville |
home:project:midimon [2008/12/09 10:11] martinsomerville |
Line 4: | Line 4: | ||
- | [[http://www.ucapps.de/midimon.html|Midimon on ucapps]] | + | [[http://www.ucapps.de/midimon.html|Midimon on uCApps]] |
- | [[http://www.midibox.org/forum/index.php/topic,4900.0.html|Midimon by Seppoman - midibox of the week]] - (request. Is someone able to put the version and source of the board and the midimon version?) | + | [[http://www.midibox.org/forum/index.php/topic,4900.0.html|Midimon by Seppoman - midibox of the week]] - (request. Is someone able to put the version and source of the board and the midimon version etc?) |
- | [[http://www.midibox.org/forum/index.php/topic,7778.0.html|Midimon by Artesia - midibox of the week]] - (request. Is someone able to put the version and source of the board and the midimon version?) | + | [[http://www.midibox.org/forum/index.php/topic,7778.0.html|Midimon by Artesia - midibox of the week]] - (request. Is someone able to put the version and source of the board and the midimon version etc?) |
- | [[http://www.ucapps.de/midimon_changelog.html|Midimon change log on ucapps]] | + | [[http://www.ucapps.de/midimon_changelog.html|Midimon change log on uCApps]] |
- | Type midimon [[http://www.midibox.org/forum/index.php?action=search;advanced;search=|here]] to search forum. | + | Type midimon or midimon* or midi_mon* [[http://www.midibox.org/forum/index.php?action=search;advanced;search=|here]] to search forum. \\ |
- | Please if you decide to build a midimon, take some photos before and after you put it in a case. Add them to a new forum topic and link it from here. Add any other info like what version of board was used and midimon version etc...it helps newbies like me a lot. | + | ---- |
+ | **Add links to photos!** | ||
+ | * Please, if you decide to build a midimon, take some photos before and after you put it in a case. Add them to a new forum topic and link((It's easy to insert a link, first sign in, click on the 'edit this page' button, then type 2 square open brackets, paste your url, and type 2 square closed brackets.)) it from here. Add any other info like what version of board was used and midimon version etc...it helps newbies a lot. | ||
+ | * Also, if you are reading this and have a midimon that you created, it'd be cool if you take a photo too and insert a link to it from here. | ||
- | Also, if you are reading this and have a midimon that you created, it'd be cool if you take a photo too and insert a link to it from here. | ||
- | (It's easy to insert a link, first sign in, click on 'edit this page' button, then type 2 square open brackets, paste your url, and type 2 square closed brackets. Add a vertical line after the url and type something more sensical if you like.) |
