home:project:midimon [2008/12/09 09:56] martinsomerville |
home:project:midimon [2008/12/20 06:29] stryd_one |
Line 1: | Line 1: | ||
+ | ====== MIDIMON ====== | ||
- | ===MIDIMON=== | ||
- | [[http://www.ucapps.de/midimon.html|Midimon on uCApps]] | + | ====== Intro ====== |
- | [[http://www.midibox.org/forum/index.php/topic,4900.0.html|Midimon by Seppoman - midibox of the week]] - (request. Is someone able to put the version and source of the board and the midimon version etc?) | + | A MIDI Monitor |
- | [[http://www.midibox.org/forum/index.php/topic,7778.0.html|Midimon by Artesia - midibox of the week]] - (request. Is someone able to put the version and source of the board and the midimon version etc?) | + | ====== Features ====== |
- | [[http://www.ucapps.de/midimon_changelog.html|Midimon change log on ucapps]] | + | Monitors MIDI messages |
- | Type midimon or midimon* [[http://www.midibox.org/forum/index.php?action=search;advanced;search=|here]] to search forum. \\ | + | ====== Skills / Equipment Required ====== |
- | ---- | + | [[:home:skills:tools|Tools]] |
- | **Add links to photos!** | + | [[:home:skills:Soldering]] |
- | * Please, if you decide to build a midimon, take some photos before and after you put it in a case. Add them to a new forum topic and link((It's easy to insert a link, first sign in, click on the 'edit this page' button, then type 2 square open brackets, paste your url, and type 2 square closed brackets.)) it from here. Add any other info like what version of board was used and midimon version etc...it helps newbies like me a lot. | ||
- | * Also, if you are reading this and have a midimon that you created, it'd be cool if you take a photo too and insert a link to it from here. | ||
+ | ====== Hardware ====== | ||
+ | ===== What modules do I need? ===== | ||
+ | Adjust List as required: | ||
+ | [[:home:mbhp:module:core | Core Module]] | ||
+ | [[:home:mbhp:module:lcd | LCD Module]] | ||
+ | ===== Parts List ===== | ||
+ | List of pots, buttons, faders and blah - suggestions on good parts and where to buy them + how to hook them up - links | ||
+ | [[:home:mbhp:parts | Where to buy Parts]] | ||
+ | ===== Connections ===== | ||
+ | Connection diagrams - links if needed (create in you projects namespace | ||
+ | ===== Enclosure / Case ===== | ||
+ | Enclosure ideas - link to case construction tips? / provide space to encourage other users to wikify their case designs | ||
+ | ==== Enclosure References ==== | ||
+ | [[:home:skills:constructing_enclosures | Constructing Enclosures]] | ||
+ | ====== Software ====== | ||
+ | ===== Setting Up ===== | ||
+ | We recommend you read [[:home:software]] before you continue. | ||
+ | ===== Download ===== | ||
+ | Links | ||
+ | ===== Setup Instructions ===== | ||
+ | Up to you | ||
+ | ====== Extra ====== | ||
+ | [[http://www.ucapps.de/midimon.html|Midimon on uCApps]] | ||
+ | [[http://www.midibox.org/forum/index.php/topic,4900.0.html|Midimon by Seppoman - midibox of the week]] - (request. Is someone able to put the version and source of the board and the midimon version etc?) | ||
+ | [[http://www.midibox.org/forum/index.php/topic,7778.0.html|Midimon by Artesia - midibox of the week]] - (request. Is someone able to put the version and source of the board and the midimon version etc?) | ||
+ | [[http://www.ucapps.de/midimon_changelog.html|Midimon change log on uCApps]] | ||
