Both sides previous revision Previous revision | Next revision Both sides next revision | ||
home:project:midimon [2008/12/09 10:08] martinsomerville |
home:project:midimon [2008/12/09 10:10] martinsomerville |
Line 19: | Line 19: | ||
**Add links to photos!** | **Add links to photos!** | ||
- | * Please, if you decide to build a midimon, take some photos before and after you put it in a case. Add them to a new forum topic and link((It's easy to insert a link, first sign in, click on the 'edit this page' button, then type 2 square open brackets, paste your url, and type 2 square closed brackets.)) it from here. Add any other info like what version of board was used and midimon version etc...it helps newbies like me a lot. | + | * Please, if you decide to build a midimon, take some photos before and after you put it in a case. Add them to a new forum topic and link((It's easy to insert a link, first sign in, click on the 'edit this page' button, then type 2 square open brackets, paste your url, and type 2 square closed brackets.)) it from here. Add any other info like what version of board was used and midimon version etc...it helps newbies a lot. |
* Also, if you are reading this and have a midimon that you created, it'd be cool if you take a photo too and insert a link to it from here. | * Also, if you are reading this and have a midimon that you created, it'd be cool if you take a photo too and insert a link to it from here. | ||
