home:project:midimon
MIDIMON
Midimon on ucapps
Midimon by Seppoman - midibox of the week - (request. Is someone able to put the version and source of the board and the midimon version?)
Midimon by Artesia - midibox of the week - (request. Is someone able to put the version and source of the board and the midimon version?)
Midimon change log on ucapps
Type midimon here to search forum.
Please if you decide to build a midimon, take some photos before and after you put it in a case. Add them to a new forum topic and link it from here. Add any other info like what version of board was used and midimon version etc…it helps newbies like me a lot.
Also, if you are reading this and have a midimon that you created, it'd be cool if you take a photo too and insert a link to it from here.
(It's easy to insert a link, first sign in, click on 'edit this page' button, then type 2 square open brackets, paste your url, and type 2 square closed brackets. Add a vertical line after the url and type something more sensical if you like.)
home/project/midimon.1228814740.txt.gz · Last modified: 2008/12/09 09:25 by martinsomerville
