home:project:midimon
MIDIMON
Midimon on uCApps
Midimon by Seppoman - midibox of the week - (request. Is someone able to put the version and source of the board and the midimon version etc?)
Midimon by Artesia - midibox of the week - (request. Is someone able to put the version and source of the board and the midimon version etc?)
Midimon change log on uCApps
Type midimon or midimon* or midi_mon* here to search forum.
Add links to photos!
  • Please, if you decide to build a midimon, take some photos before and after you put it in a case. Add them to a new forum topic and link1) it from here. Add any other info like what version of board was used and midimon version etc…it helps newbies a lot.
  • Also, if you are reading this and have a midimon that you created, it'd be cool if you take a photo too and insert a link to it from here.
1)
It's easy to insert a link, first sign in, click on the 'edit this page' button, then type 2 square open brackets, paste your url, and type 2 square closed brackets.
home/project/midimon.1228817486.txt.gz · Last modified: 2008/12/09 10:11 by martinsomerville
