Elaborate and test on all development platforms!
This page describes the use of the autotools-based mios application skeleton.
Announcement forum post: http://www.midibox.org/forum/index.php?topic=10338.0
You can download the skeleton in the annoucement forum post.
As of today, quite all applications uses the same standard procedure to be build and installed. That procedure is composed of the following steps :
To each of those three steps is associated a standard command. The achieve the build and installation of a program/library we do :
./configure <configure informations> make all make install
Note that the 'all' in 'make all' may be ommited.
However writing the configure script and the Makefile (that consumes the make command) can be very tedious, moreover if you want them to be portable and easily maintainable… That's when the Autotools come into action!
The, so-called, AutoTools are a set of gnu tools to automate the build of gnu-like applications. They are made as a layer above traditional bash shell and make tool. They use simple configuration files to generate the scripts and Makefile(s) required to build the application.
AutoTools comprise (amongst others) :
We can note the following facts about the actual C skeleton :
Let's detail the exact implications in the try to make it better :
A toolchain is the set of tools to go from source files to executable application :
(C source file) ⇒ compile ⇒ (Assembly source file) ⇒ assemble ⇒ (Object file) [ ⇒ librarian ⇒ (Reusable library) ] ⇒ link ⇒ (Executable application)
Thus a toolchain generally includes :
To enable integration with the AutoTools, you must have your toolchain to follow the naming style of the gnu toolchain. That is : tools must be name as the standard gnu tools prefixed by the platform host (which follows the scheme processor-vendor-os
). So :
Also those tools needs to take the standard options of the gnu tools. So we need to have a wrapper script around sdcc, gpasm, gplib and gplink, that would take care of transparently fixing the asm, and that would use the GCC command line style.
Host processors are :
Host OS is (obviously :)) mios
Which makes four possible targets/hosts, which are:
Support for PIC18F4685 : You need sdcc-svn and gputils-0.13.5 versions at least to get support for the PIC18F4685 processor (sdcc-svn
and>=gputils-0.13.5
packages on Gentoo Linux)
You obviously need the AutoTools so…
Please refer to :
It is time to choose where you want to install all your MIOS-related things.
Basically, here where the different things will go :
${prefix}/bin
will contain the tools from the toolchain${prefix}/mios/${host}
will contain platform-dependent stuff${prefix}/mios/*
will contain platform-independent stuff
where ${prefix}
is by default /usr/local
A more complete view of the filesystem tree is :
${prefix}/
bin/
tools (eg. pic18f4685-microchip-mios-gcc)mios/
include/
libraries' header files (eg. cmios.h, can.h…)share/
shared files (eg. documentations, licenses…)${host}/
lib/
: libraries (eg. libcmios.a, libcan.a…)scripts/
: linker scripts
You can specify the ${prefix}
value by passing –prefix=value
to your ./configure
command-line calls. For instance :
./configure ... --prefix=/usr
Note that if you chose to configure a certain prefix for one of your library, you will have to put the exact same prefix in the configure of all your libraries and applications.
So you have to choose a place in your filesystem and to abide by your choice! (I personally let the standard /usr/local/
prefix which makes me less to type on the command line.)
In fact, the choice of the${prefix}
formios-pic16-toolchain
is independent from anything else. But that is the sole one.
Details…
cd mios-pic16-toolchain ./configure --target=pic18f4685-mios make sudo make install
Details…
cd libcmios ./configure --host=pic18f4685-mios make sudo make install
Here we will describe some of the features of the skeleton, by giving a step-by-step guide to use the skeleton.
The skeleton, in its delivery form, already contains a simple print “Hello, world!” on the LCD. So, we will do a little more : fetch an encoder and print its value on the LCD. Let's call our application the 'one-encoder' application.
By doing this we will see how to :
So let's start our fabulous application. First copy the skeleton folder and rename its copy one-encoder
cp -r mios-skeleton-1.9f-r1/ one-encoder cd one-encoder/
Here are the files provided in the skeleton :
config.sub
configure.in
Makefile.am
README
src/
main.c
Makefile.am
Three files are controlling the build and installation behavior :
configure.in
- Package configuration tweakingMakefile.am
- Root directory build tweakingsrc/Makefile.am
- Source directory build tweaking
There is another file in the root directory (config.sub
), and there will be more (generated) files after the first AutoTools launch. However you will never have to modify them. Just understand that *.am
files are used to generated *.in
files, which in turn are used to generate *
files. (For instance, Makefile.am
is the source to generate Makefile.in
which itself is the source to generate Makefile
You will have to launch the first auto-configuration. This will be done by calling the auto(re)conf
command in a certain way.
After that, each and every time you will modify one of those three files, then, at the time you will launch the make
command again, the package will automatically be reconfigured (in the sense of calling autoconf
But, for now, let's copy the skeleton and tweak a bit its configure.in
file…
Open the configure.in
file with your favorite editor. Here is its content :
# -*- Autoconf -*- # Process this file with autoconf to produce a configure script. AC_PREREQ(2.61) AC_INIT(MIOS C Skeleton, 1.9f-r1, http://www.ucapps.de/, mios-c-skeleton) AC_MIOS_HOSTS([ pic18f452-mios pic18f4520-mios pic18f4620-mios pic18f4685-mios ]) AC_MIOS_HOST_PREFIX AM_INIT_AUTOMAKE([foreign]) # Checks for programs. AM_CHECK_MIOS_TOOLCHAIN # Checks for libraries. AC_LIB_PREFIX # Checks for header files. AC_CHECK_HEADERS([pic18fregs.h], [], [ AC_MSG_FAILURE([Can't compile without PIC header files])]) AC_CHECK_HEADERS([cmios.h], [], [ AC_MSG_FAILURE([Can't compile without cmios.h])]) # Checks for typedefs, structures, and compiler characteristics. AC_C_CONST AC_C_VOLATILE # Checks for library functions. AC_CONFIG_SRCDIR([src/main.c]) AC_CONFIG_HEADERS([src/config.h]) AC_CONFIG_FILES([ Makefile src/Makefile ]) AC_OUTPUT
Modify line 4 to be as follows :
AC_INIT(My One Encoder App., 0.1, http://www.example.com/, one-encoder)
Let's tell AutoTools to make the first generation and install the missing files :
autoreconf --install
This will install the compile
, missing
, install-sh
, config.guess
and depcomp
scripts. You don't need take any attention to them. There are here for the AutoTools to work correctly.
This will also generate the configure
script and Makefile.in
Here is the content of src/Makefile.am
## Process this file with automake to produce Makefile.in bin_PROGRAMS = mios-skeleton mios_skeleton_SOURCES = main.c # Add C headers and sources here LDADD = -lcmios CFLAGS = --disable-warning 85 CFLAGS += --fommit-frame-pointer CFLAGS += --opt-code-speed CFLAGS += --optimize-goto CFLAGS += --optimize-cmp CFLAGS += --optimize-df CFLAGS += --obanksel=2 #CFLAGS += --keep-asm
Modify lines 2 and 3 of the file so that it looks like the following :
bin_PROGRAMS = one-encoder one_encoder_SOURCES = main.c
By doing that we modified the name of the build application.
Your application has now all the things needed to be build using the traditional build procedure. So let's see what are the options of the configure script :
./configure --help=short
This command shows all the options specific to your application. As you can see, there isn't any specific options (yet!).
So, for now, configure the application in a basic manner :
You might notice that by running the configure
script, the Makefile
files have now been generated.
Now build your application :
make
Check the src/
folder's content. You will find there your one-encoder.hex
file ready to be uploaded to your MidiBox!
Isn't it simple and easy ??
Specifying a library :
LDADD = -lcmios
Checking for the availability of a header file at configure time :
Write about :
one_encoder_SOURCES = main.c test.h test.c
Write test.h, test.c and call test.c from main.c
Write about :
## Process this file with automake to produce Makefile.in SUBDIRS = src dist_doc_DATA = README
Write about :
