====== How to program a PIC16F87x or PIC18F452 ====== For the MIDIbox project it is **not** required to purchase an expensive, "ready-made" programmer in order to get the firmware into the PIC. Instead you could buy a pre-programmed PIC from SmashTV or Mike, you could ask in the [[http://forum.midibox.org|MIDIbox Forum]] for help, or you could build a PIC programmer by yourself. There are many schematics available on the web. The [[http://www.ucapps.de/mbhp_burner.html|MBHP_BURNER]] module is one of such DIY programmers, and it works reliable. FIXME explain the term **programming**, because it could be confusing for non-technicans
