installing_gputils_and_sdcc_on_fedora_core_5
Differences
Link to this comparison view
installing_gputils_and_sdcc_on_fedora_core_5 [2007/08/14 17:50]
installing_gputils_and_sdcc_on_fedora_core_5 [2007/08/14 17:50] (current)
Line 1: Line 1:
 +====== Installing GPUTILS and SDCC on FC5 ======
 +This is just a clone of the gentoo details but specific for FC5.  Should work for anything with yum and rpm.
 +===== install GPUTILS =====
 +the FC5 '​extras'​ repository has a gputils package, so we can install it with:
 +''​yum install gputils''​
 +===== Install SDCC 2.5 =====
 +yum didn't find a package for SDCC 2.5, so lets install it from an RPM.  Download a 2.5.0 RPM from:
 +[[http://​rpmfind.net/​linux/​rpm2html/​search.php?​query=sdcc&​submit=Search+...|RPMFind SDCC search]] (I used "​sdcc-2.6.0-1mdk.i586.rpm"​).
 +and install it (either with 'rpm -ivh <​filename>'​ or by opening it with the package installer from the firefox download window and following onscreen instructions.
 +===== Testing it all =====
 +* download [[http://​www.ucapps.de/​mios/​clockbox_v1_0.zip]].
 +<code bash>
 +unzip clockbox_v1_0.zip
 +cd clockbox_v1_0
 +make
 +</​code>​
 +Output should look like:
 +<code bash>
 +gpasm -c -DSTACK_HEAD=0x37f -DSTACK_IRQ_HEAD=0x33f -I mios_wrapper mios_wrapper/​mios_wrapper.asm -o _output/​mios_wrapper.o
 +sdcc -S -mpic16 -p18F452 --fstack --fommit-frame-pointer --optimize-goto --optimize-cmp --disable-warning 85 --obanksel=2 -pleave-reset-vector -DDEBUG_MODE=0 main.c -o _output/​main.asm
 +Processor: 18F452
 +perl tools/​fixasm.pl _output/​main.asm
 +gpasm -c _output/​main.asm -o _output/​main.o
 +sdcc -S -mpic16 -p18F452 --fstack --fommit-frame-pointer --optimize-goto --optimize-cmp --disable-warning 85 --obanksel=2 -pleave-reset-vector -DDEBUG_MODE=0 mclock.c -o _output/​mclock.asm
 +Processor: 18F452
 +perl tools/​fixasm.pl _output/​mclock.asm
 +gpasm -c _output/​mclock.asm -o _output/​mclock.o
 +sdcc -S -mpic16 -p18F452 --fstack --fommit-frame-pointer --optimize-goto --optimize-cmp --disable-warning 85 --obanksel=2 -pleave-reset-vector -DDEBUG_MODE=0 pic18f452.c -o _output/​pic18f452.asm
 +Processor: 18F452
 +perl tools/​fixasm.pl _output/​pic18f452.asm
 +gpasm -c _output/​pic18f452.asm -o _output/​pic18f452.o
 +gplink -s project.lkr -m -o project.hex _output/​mios_wrapper.o _output/​main.o _output/​mclock.o _output/​pic18f452.o
 +perl tools/​hex2syx.pl project.hex
 +Block 003000-0033FF allocated - Checksum: 62
 +Block 003400-0037FF allocated - Checksum: 52
 +Block 003800-003BFF allocated - Checksum: 07
 +Block 003C00-003FFF allocated - Checksum: 73
 +rm _output/​main.asm _output/​mclock.asm _output/​pic18f452.asm
 +</​code>​
installing_gputils_and_sdcc_on_fedora_core_5.txt ยท Last modified: 2007/08/14 17:50 (external edit)
