integrated_circuit [2016/06/15 08:59] psykhaze [MIDIbox-related ICs] |
integrated_circuit [2016/06/15 12:16] psykhaze |
Line 16: | Line 16: | ||
* **ULSI** (ultra large-scale integration): More than 1 million electronic components per chip\\ | * **ULSI** (ultra large-scale integration): More than 1 million electronic components per chip\\ | ||
- | IC are usually packaged in a plastic or ceramic case with external connector pins. | + | IC are usually packaged in a plastic or ceramic case with external connector pins.Some ICs used in midibox designs: |
+ | <wrap info>Mouser Referenced Datasheets are given for example.</wrap> | ||
- | Some ICs used in midibox designs: | + | ^ Description ^Type ^Mouser Ref ^ Datasheet Link ^ |
- | + | |74HC165 |Serial Register |595-CD74HC165EE4 |[[http://www.mouser.com/ds/2/405/cd74hc165-441105.pdf|74HC165]]| | |
- | ^ Description ^Type ^Mouser Ref ^Reichelt ref^ Digikey ref^ | + | |74HC595 |Serial Register |595-CD74HC595E |[[http://www.mouser.com/ds/2/405/cd74hc595-406651.pdf|74HC595]]| |
- | |74HC165 |Serial Register |595-CD74HC165EE4 | | | | + | |74HCT541 |Line Driver |595-D74HCT541E |[[http://www.mouser.com/ds/2/405/cd74hct541-439778.pdf|74HCT541]]| |
- | |74HC595 |Serial Register |595-CD74HC595E | | | | + | |74HC00 |Logic Gate |595-CD74HC00EE4 |[[http://www.mouser.com/ds/2/405/cd74hc00-441639.pdf|74HC00]]| |
- | |74HCT541 |Line Driver |595-D74HCT541E | | | | + | |6N138 |OptoCoupler |512-6N138M |[[http://www.mouser.com/ds/2/149/6N138M-770001.pdf|6N138]]| |
- | |74HC00 |Logic Gate |595-CD74HC00EE4 | | | | + | |MOS4051 |Multiplexer switch |595-CD74HC4051M96 |[[http://www.mouser.com/ds/2/405/cd74hc4051-441652.pdf|MOS4051]]| |
- | |6N138 |OptoCoupler |512-6N138M | | | | + | |TL072 |Operational Amplifier |595-TL072ACP |[[http://www.mouser.com/ds/2/405/tl072a-557364.pdf|TL072]]| |
- | |MOS4051 |Multiplexer switch |595-CD74HC4051M96 | | | | + | |TL074 |Operational Amplifier |512-LM324N |[[http://www.mouser.com/ds/2/149/LM324-195664.pdf|TL074 / LM324]]| |
- | |TL072 |Operational Amplifier |595-TL072ACP | | | | + | |MCP6004 |Operational Amplifier |579-MCP6004-E/P |[[http://www.mouser.com/ds/2/268/21733e-41017.pdf|MCP600X]]| |
- | |TL074 |Operational Amplifier |512-LM324N | | | | + | |MCP3208 |Analog>Digital converter|579-MCP3208CIP |{{:home:datasheets:mcp320x-68472.pdf|MCP3208}}| |
- | |MCP6004 |Operational Amplifier |579-MCP6004-E/P | | | | + | |MCP3428 |Analog>Digital converter|579-MCP3428E/SL |[[http://www.mouser.com/ds/2/268/22226a-81911.pdf|MCP3428]]| |
- | |MCP3208 |Analog>Digital converter|579-MCP3208CIP | | | | + | |MAX525 |Digital>Analog converter|700-MAX525BCPP |[[http://www.mouser.com/ds/2/256/MAX525-105108.pdf|MAX525]]| |
- | |MCP3428 |Analog>Digital converter|579-MCP3428E/SL | | | | + | |CD22M3494EZ |Crosspoint switch |968-CD22M3494EZ |[[http://www.mouser.com/ds/2/465/cd22m3494-553706.pdf|CD22M3494]]| |
- | |MAX525 |Digital>Analog converter|700-MAX525BCPP | | | | + | |PIC16F88 |Microcontroller |579-PIC16F88-I/P |[[http://www.mouser.com/ds/2/268/30487b-15915.pdf|PIC16F88]]| |
- | |CD22M3494EZ |Crosspoint switch |968-CD22M3494EZ | | | | + | |
- | |PIC16F88 |Microcontroller |579-PIC16F88-I/P | | | | + | |
==== Datasheets ==== | ==== Datasheets ==== | ||
- | <wrap info>Mouser Referenced Datasheets are given for example.</wrap> | ||
- | * [[http://www.mouser.com/ds/2/405/cd74hc165-441105.pdf|74HC165]] | + | |
- | * [[http://www.mouser.com/ds/2/405/cd74hc595-406651.pdf|74HC595]] | + | |
- | * [[http://www.mouser.com/ds/2/405/cd74hct541-439778.pdf|74HCT541]] | + | |
- | * [[http://www.mouser.com/ds/2/405/cd74hc00-441639.pdf|74HC00]] | + | |
- | * [[http://www.mouser.com/ds/2/149/6N138M-770001.pdf|6N138]] | + | |
- | * [[http://www.mouser.com/ds/2/405/cd74hc4051-441652.pdf|MOS4051]] | + | |
- | * [[http://www.mouser.com/ds/2/405/tl072a-557364.pdf|TL072]] | + | |
- | * [[http://www.mouser.com/ds/2/149/LM324-195664.pdf|TL074 / LM324]] | + | |
- | * [[http://www.mouser.com/ds/2/268/21733e-41017.pdf|MCP600X]] | + | |
- | * {{:home:datasheets:mcp320x-68472.pdf|MCP3208}} | + | |
- | * [[http://www.mouser.com/ds/2/268/22226a-81911.pdf|MCP3428]] | + | |
- | * [[http://www.mouser.com/ds/2/256/MAX525-105108.pdf|MAX525]] | + | |
- | * [[http://www.mouser.com/ds/2/465/cd22m3494-553706.pdf|CD22M3494]] | + | |
- | * [[http://www.mouser.com/ds/2/268/30487b-15915.pdf|PIC16F88]] | + |
