jjonas
Differences
Link to this comparison view
Both sides previous revision Previous revision
Last revision Both sides next revision
jjonas [2016/03/22 18:34]
jjonas
jjonas [2016/03/22 18:44]
jjonas
Line 1251: Line 1251:
 Each mixer map page has 16 different slots for customised commands that can be sent simultaneously. The first two pages of a mixer map define, first, the //output port// on which the message for each of the 16 slots is sent, and second, the //MIDI channel// on which the message for each slot is sent. The default value for Port is '​Def.',​ i.e. the setting is taken from the MIDI Router page (see section 2.1.2. or Appendix 3). The default MIDI channel is '# 1' for the first slot, '# 2' for the second, and so on. Each mixer map page has 16 different slots for customised commands that can be sent simultaneously. The first two pages of a mixer map define, first, the //output port// on which the message for each of the 16 slots is sent, and second, the //MIDI channel// on which the message for each slot is sent. The default value for Port is '​Def.',​ i.e. the setting is taken from the MIDI Router page (see section 2.1.2. or Appendix 3). The default MIDI channel is '# 1' for the first slot, '# 2' for the second, and so on.
-The Port and MIDI channel are the foundational settings for each mixer map slot, without which the messages won't be sent to the right place; ​the don't send any command by themselves, they just set the conduit for the commands from the other pages. For example, if you've set track G1T1 to play a synthesizer connected to OUTPUT1 on MIDI channel 5 (settings made on the track'​s EVENT page), you should set one of the slots on the mixer map page to that port and that MIDI channel to send a message from the mixer map to that synthesizer. While you're on the MIXER page, the port and channel for the slot in the current cursor position will always be visible in the upper right corner of the right LCD.+The Port and MIDI channel are the foundational settings for each mixer map slot, without which the messages won't be sent to the right place; ​they don't send any command by themselves, they just set the conduit for the commands from the other pages. For example, if you've set track G1T1 to play a synthesizer connected to OUTPUT1 on MIDI channel 5 (settings made on the track'​s EVENT page), you should set one of the slots on the mixer map page to that port and that MIDI channel to send a message from the mixer map to that synthesizer. While you're on the MIXER page, the port and channel for the slot in the current cursor position will always be visible in the upper right corner of the right LCD.
 Once Port and MIDI channel are in order, the actual messages that you can send are: Once Port and MIDI channel are in order, the actual messages that you can send are:
Line 1272: Line 1272:
 There are four ways to send mixer map commands to their destinations. There are four ways to send mixer map commands to their destinations.
-The easiest way is to press a GPB button under an entry that has some value other than '​---'​ in it. Pressing the GP button will simply send once the value or command ​in the slot of the active pageThis is useful ​e.g. for sending one-off ​commands ​like Program Change. The second option is available in the utility menu: '​Dump'​ (GPB8) will send all the commands in the 16 slots of all 10 command pages to the ports and MIDI channels set for each slot. The third option can be enabled in the mixer utility menu (press & hold SELECT): LiveSend can be set '​on'​ or '​off'​. If LiveSend is '​on',​ the values in the slots of all pages in the current mixer map will be active all the time, and all changes will be updated immediately. For example, mixer page 4 (Volume) could be used as a centralised volume control for all your MIDI equipment.+The easiest way is to press a GP button under an entry. Pressing the GP button will simply send once the values ​or commands ​in the whole "​stack" ​of slots (i.e. commands ​from page 3, page 4 etc.). The second option is available in the utility menu: '​Dump'​ (GPB8) will send all the commands in the 16 slots of all 10 command pages to the ports and MIDI channels set for each "​stack"​ of slots. The third option can be enabled in the mixer utility menu (press & hold SELECT): LiveSend can be set '​on'​ or '​off'​. If LiveSend is '​on',​ the values in the slots of all pages in the current mixer map will be active all the time, and all changes will be updated immediately. For example, mixer page 4 (Volume) could be used as a centralised volume control for all your MIDI equipment.
 The fourth way to send mixer map values is on the SONG page, as a song position action ('​Mixer 🡪 Map #'). The fourth way to send mixer map values is on the SONG page, as a song position action ('​Mixer 🡪 Map #').
jjonas.txt · Last modified: 2016/03/24 21:40 by admin
