ju_control_roland_alpha_juno_control_panel_cs
Differences
Link to this comparison view
Both sides previous revision Previous revision
Next revision Both sides next revision
ju_control_roland_alpha_juno_control_panel_cs [2012/12/09 19:36]
lemonhorse
ju_control_roland_alpha_juno_control_panel_cs [2012/12/09 19:39]
lemonhorse
Line 357: Line 357:
   || --- V1.001 (12/​2012) ​   || --- V1.001 (12/​2012) ​
   || --- JuCtrl MIDI IN: Channel Pressure (MIDI Aftertouch) enabled. ​   || --- JuCtrl MIDI IN: Channel Pressure (MIDI Aftertouch) enabled. ​
-  ||            Note: Juno Keyboard do NOT have Aftertouch. But with another Keyboard or Sequencer +  ||            Note: The Juno Keyboard do NOT have Aftertouch. But with another Keyboard or Sequencer
-  ||            You can use all the nice Aftertouch Effects of the Alpha Juno.+  ||            You can use all the nice Aftertouch Effects of the Alpha Juno.
 +  ||            The JuCtrl CS will pass through all Aftertouch MIDI data to the Alpha Juno now - so better update to V1.001
ju_control_roland_alpha_juno_control_panel_cs.txt · Last modified: 2017/09/19 12:14 by lemonhorse
