Both sides previous revision Previous revision | Last revision Both sides next revision | ||
ju_control_roland_alpha_juno_control_panel_cs [2012/12/09 19:39] lemonhorse |
ju_control_roland_alpha_juno_control_panel_cs [2012/12/27 20:20] lemonhorse |
Line 357: | Line 357: | ||
|| --- V1.001 (12/2012) | || --- V1.001 (12/2012) | ||
|| --- JuCtrl MIDI IN: Channel Pressure (MIDI Aftertouch) enabled. | || --- JuCtrl MIDI IN: Channel Pressure (MIDI Aftertouch) enabled. | ||
- | || Note: The Juno Keyboard do NOT have Aftertouch. But with another Keyboard or Sequencer | ||
- | || You can use all the nice Aftertouch Effects of the Alpha Juno. | ||
|| The JuCtrl CS will pass through all Aftertouch MIDI data to the Alpha Juno now - so better update to V1.001 | || The JuCtrl CS will pass through all Aftertouch MIDI data to the Alpha Juno now - so better update to V1.001 | ||
+ | || Note: The Juno Keyboard does NOT have the Aftertouch function itself. But with another Keyboard or Sequencer | ||
+ | || connected (to JuCtrl MIDI IN) You can use all the nice Aftertouch Effects of the Roland Alpha Juno. | ||
