ju_control_roland_alpha_juno_control_panel_cs [2012/12/09 19:39] lemonhorse |
ju_control_roland_alpha_juno_control_panel_cs [2017/09/19 12:14] lemonhorse [MIDIBox Juno Control (JuCtrl)] |
Line 1: | Line 1: | ||
====== MIDIBox Juno Control (JuCtrl) ====== | ====== MIDIBox Juno Control (JuCtrl) ====== | ||
- | {{http://www.subfrequenz.net/visuals/albums/userpics/10001/20120316MidiboxJuCTRL002.jpg}} | + | {{https://www.subf.net/visuals/albums/import_pool/2017Archiv2/20120316MidiboxJuCTRL002.jpg}} |
====== Project Description ====== | ====== Project Description ====== | ||
Line 357: | Line 357: | ||
|| --- V1.001 (12/2012) | || --- V1.001 (12/2012) | ||
|| --- JuCtrl MIDI IN: Channel Pressure (MIDI Aftertouch) enabled. | || --- JuCtrl MIDI IN: Channel Pressure (MIDI Aftertouch) enabled. | ||
- | || Note: The Juno Keyboard do NOT have Aftertouch. But with another Keyboard or Sequencer | ||
- | || You can use all the nice Aftertouch Effects of the Alpha Juno. | ||
|| The JuCtrl CS will pass through all Aftertouch MIDI data to the Alpha Juno now - so better update to V1.001 | || The JuCtrl CS will pass through all Aftertouch MIDI data to the Alpha Juno now - so better update to V1.001 | ||
+ | || Note: The Juno Keyboard does NOT have the Aftertouch function itself. But with another Keyboard or Sequencer | ||
+ | || connected (to JuCtrl MIDI IN) You can use all the nice Aftertouch Effects of the Roland Alpha Juno. | ||
