kicad
Differences
Link to this comparison view
Both sides previous revision Previous revision
Next revision
Previous revision
kicad [2016/06/27 12:08]
psykhaze [4. Video Tutorial]
kicad [2016/07/18 00:32]
psykhaze [5. Going Further]
Line 23: Line 23:
   * First you have to create a library including all the components you will need for your design.This allow to add new components to a basic library by designing pin layout for a new used IC.   * First you have to create a library including all the components you will need for your design.This allow to add new components to a basic library by designing pin layout for a new used IC.
-{{:​component_creation.png?​direct&​300|}}+{{:​component_creation.png?​direct&​600|}}
   * Then you have to create a Schematic, which is the Conceptual Drawing of your electronic design. It's how components are connected together.   * Then you have to create a Schematic, which is the Conceptual Drawing of your electronic design. It's how components are connected together.
Line 31: Line 31:
   * After this you will have to make a link between components and footprints. Footprints are the layouts of pads, holes, and silkscreen drawings that are actually manufactured into the PCB, corresponding to each component.   * After this you will have to make a link between components and footprints. Footprints are the layouts of pads, holes, and silkscreen drawings that are actually manufactured into the PCB, corresponding to each component.
-{{:​footprint.png?​nolink&​direct&​300|}}+{{:​footprint.png?​nolink&​direct&​600|}}
   * Lastly, the PCB Design by itself. Based upon your components list and associated footprints , you can create the PCB by placing footprints at the right place and make routing between them (which is connecting components footprints by making copper paths). You can also use the famous 3D viewer to see a simulation of the result.   * Lastly, the PCB Design by itself. Based upon your components list and associated footprints , you can create the PCB by placing footprints at the right place and make routing between them (which is connecting components footprints by making copper paths). You can also use the famous 3D viewer to see a simulation of the result.
Line 40: Line 40:
 =====4. Video Tutorials ===== =====4. Video Tutorials =====
-{{youtube>​zK3rDhJqMu0?​medium}} +{{youtube>​zK3rDhJqMu0?​small}}
-{{youtube>​cS91IA_Qwdk?​medium}}+{{youtube>​YoyO8OqKqVk?​small}}
 +{{youtube>​cS91IA_Qwdk?​small}}
 +{{youtube>​l6eyhptlev8?​small}}
 +{{youtube>​PlYtGGD5mZ4?​small}}
-=====5. Going Further=====
-Getting Started Manual to be found here :+=====5. Going Further=====
-http://​docs.kicad-pcb.org/​en/​getting_started_in_kicad.html#​introduction-to-kicad+  * **[[https://​www.youtube.com/​playlist?​list=PLCNJWVn9MJuORLQ3ds_U3D7RILfE4zdoL| Further Video Tutorials]]**
 +  * [[http://​docs.kicad-pcb.org/​en/​getting_started_in_kicad.html#​introduction-to-kicad|KiCAD Getting started Manual]]
 +  * [[http://​smisioto.no-ip.org/​elettronica/​kicad/​kicad-en.htm|KiCAD Librairies]]
 ===== 6.Tips ===== ===== 6.Tips =====
kicad.txt · Last modified: 2016/07/18 00:32 by psykhaze
