led
Differences
Link to this comparison view
Both sides previous revision Previous revision
Next revision
Previous revision
led [2016/06/15 12:40]
psykhaze [Introduction]
led [2016/07/10 15:03]
psykhaze [White / Blue LEDs issue]
Line 6: Line 6:
 LED is an industry acronym for **Light Emitting Diode**. These are usually small little "​bulbs"​ that glow in different colors when they are "​turned on" ​ LED is an industry acronym for **Light Emitting Diode**. These are usually small little "​bulbs"​ that glow in different colors when they are "​turned on" ​
-(most common colors are red, green,​yellow,​ blue or white) // +//(most common colors are red, green,​yellow,​ blue or white) //
Line 21: Line 21:
 It has been proven recently that the use of **high brightness White and Blue LEDs are not good to human sight**. The output light spectrum for these LEDs is some harsh for the eye. You should prefer using other colors LEDs or not using them too much. It has been proven recently that the use of **high brightness White and Blue LEDs are not good to human sight**. The output light spectrum for these LEDs is some harsh for the eye. You should prefer using other colors LEDs or not using them too much.
 +=====LED Matrix=====
 +{{ ::​neonking:​ledmatrix.jpg?​direct&​600 |}}
led.txt · Last modified: 2016/07/10 15:03 by psykhaze
