loopa-eurorack-panel
Differences
Link to this comparison view
Both sides previous revision Previous revision
Next revision
Previous revision
Next revision Both sides next revision
loopa-eurorack-panel [2022/01/16 08:19]
phatline [Building and BOM]
loopa-eurorack-panel [2022/01/21 12:49]
phatline [Frontpanel]
Line 28: Line 28:
 All necessery Information is printet on the PCB, but also check the Shematic...\\ ​ All necessery Information is printet on the PCB, but also check the Shematic...\\ ​
-5x [[https://​www.buerklin.com/​de/​Montageblock/​p/​17H917|"Leiterplatten Montageblock aka Standoffs]]\\+5x [[https://​www.buerklin.com/​de/​Montageblock/​p/​17H917|Leiterplatten Montageblock aka Standoffs]]\\
 3x [[https://​www.mouser.at/​ProductDetail/​TE-Connectivity/​1-215079-0?​qs=sGAEpiMZZMu2UVWuvJ5cF0NzRP25WJYp|Micromatch Socket 2x5Pole 1,27mm]]\\ 3x [[https://​www.mouser.at/​ProductDetail/​TE-Connectivity/​1-215079-0?​qs=sGAEpiMZZMu2UVWuvJ5cF0NzRP25WJYp|Micromatch Socket 2x5Pole 1,27mm]]\\
 6x [[https://​www.mouser.at/​ProductDetail/​TE-Connectivity/​1-2178712-0?​qs=Xjc0wECptJBhQ3iBLfHBBw%3D%3D|Micromatch Crimp Connector]] you need only 3, the 3+ is for fails by crimping\\ 6x [[https://​www.mouser.at/​ProductDetail/​TE-Connectivity/​1-2178712-0?​qs=Xjc0wECptJBhQ3iBLfHBBw%3D%3D|Micromatch Crimp Connector]] you need only 3, the 3+ is for fails by crimping\\
Line 34: Line 34:
 1x [[https://​www.mouser.at/​ProductDetail/​Molex/​67068-7041?​qs=%2Fha2pyFadugeFcqiSbHe2F3FlkyTY7p9rg69fYk%252bS0tr8kIPu4fJmw%3D%3D|USB-Socket]]\\ 1x [[https://​www.mouser.at/​ProductDetail/​Molex/​67068-7041?​qs=%2Fha2pyFadugeFcqiSbHe2F3FlkyTY7p9rg69fYk%252bS0tr8kIPu4fJmw%3D%3D|USB-Socket]]\\
 8x [[https://​www.mouser.at/​ProductDetail/​CUI-Devices/​SJ1-3535NG?​qs=sGAEpiMZZMv0W4pxf2HiVz9SCMkER55fXrlpiF5mEoVt2p3Qc8GC6g%3D%3D|3,​5 Audio Jack]]\\ 8x [[https://​www.mouser.at/​ProductDetail/​CUI-Devices/​SJ1-3535NG?​qs=sGAEpiMZZMv0W4pxf2HiVz9SCMkER55fXrlpiF5mEoVt2p3Qc8GC6g%3D%3D|3,​5 Audio Jack]]\\
 +12x [[https://​www.mouser.at/​ProductDetail/​Lumex/​SSL-LX30FT4ID?​qs=sGAEpiMZZMuCm2JlHBGefjo7mRik%2FjcaqjK5FJOZhDc%3D|Round 3mm Thruhole LEDs-RED-Flat]]\\
 +4x [[https://​www.mouser.at/​ProductDetail/​Lumex/​SSL-LX30FT4GD?​qs=sGAEpiMZZMuCm2JlHBGefjo7mRik%2FjcaResH8h9wozw%3D|Round 3mm Thruhole LEDs-GREEN-Flat]]
 And there will be some additional Fasting Material, like bolts, Screws, Standoffs, that i dont know right now, because the first protoype has to be built first...\\ And there will be some additional Fasting Material, like bolts, Screws, Standoffs, that i dont know right now, because the first protoype has to be built first...\\
 ====== Frontpanel====== ====== Frontpanel======
-{{:​phatline:​Frontpanel.jpg?​700|}}\\ +{{:​phatline:​Euro-LoopA-Frontpanel-growing.jpg?900|}}\\
-I made a DXF File which you can send to [[https://​www.formulor.de/|Formulor in Germany]]\\ +**I made a DXF File which you can send to:** (once the prototypestate is gone)\\
- +[[https://​www.formulor.de|Formulor in Germany]] ​- Acrylic ... 2Pieces incl shipping 42€\\
-i panalized it so there are 2 Plates ​in it\\ +[[https://​shop.frontpanels.de/​custom-panels|frontpanels.de ​in germany]] my choose\\
-I payed 40€ summed for booth plates incl shipping from Germany to Austria\\ +[[https://​thebeast.co.uk/​2d/​|The Beast - UK]]\\
-{{:phatline:​2xLRE-OLED-BAR-DXF.zip?700|}}\\ +[[https://​www.schaeffer-ag.de/en/|Schaeffer-ag.de]]
 **Recommend Material**\\ **Recommend Material**\\
-3mm x 128.5 x 188.58 Aluminium, anodised)\\+2mm x 128.5 x 188.58 Aluminium, anodised\\
 +contact frontpanels:​ info@frontpanels.de\\
 +{{:​phatline:​Frontpanels-Euroloopa.zip?​900|}} - NOT TESTET - REVERSE ENGENEERING!!!!!!\\
loopa-eurorack-panel.txt · Last modified: 2022/02/24 21:27 by phatline
